03-24-2014, 05:44 AM | #1 |
RCC Addict Join Date: Jan 2011 Location: Razorback Haven
| Dinky servo mount vs stock setup?
What is better? I have the dinky mount setup on mine, but I feel like it puts more stress on my servo. Is the stock setup easier on the servo?
03-24-2014, 08:11 AM | #2 |
Quarry Creeper Join Date: Jun 2012 Location: Next to you
| Re: Dinky servo mount vs stock setup?
I have not noticed a difference. I do like the s-mount due to how low the servo sits.
03-24-2014, 11:21 AM | #3 |
Seems like I have more steering and power with the dinky setup.
03-24-2014, 12:21 PM | #4 |
Pebble Pounder Join Date: Feb 2004 Location: Born in a crossfire hurricane
I don't think your servo would know the difference. The Dinky link still mounts the servo in the standard holes. You've only moved the servo down and to the side. As was mentioned you could gain a little more mechanical advantage because the servo arm is more in line with the tierod mount, that should only help the servo.
03-24-2014, 02:25 PM | #5 |
Quarry Creeper Join Date: Sep 2013 Location: Norway
The only thing giving force to your servo is the servo arm, turning linear force from your drag arm to rotating momentum on the servo Theoretically it is of absolutely no influence where you put your servo. Reduce stress on your servo? Use a shorter servo arm. Or create a weak link that will go before your servo. For instance a plastic servo arm.
03-24-2014, 10:11 PM | #6 |
In the stock location the servo arm is swinging away from the steering motion On the dinky it swings towards it. Which provides sharper turns or move the drag link in one Hoke for more servo arm leverage on the steering. Withbthecsame amount of steering Last edited by evan03; 03-24-2014 at 10:14 PM. |
Dinky servo mount vs stock setup? - Similar Threads | ||||
dinky rc servo mount | wraithchild | Axial Wraith | 5 | 11-03-2012 12:16 AM |
non stock servo mount for VP hurtz | 27cameron | Axial AX-10 Scorpion | 4 | 03-22-2010 12:28 AM |
