03-24-2014, 11:33 PM | #1 |
Pebble Pounder Join Date: Dec 2013 Location: Burbank
| Which springs for Gmade xd piggys
Hey all, building my crawler/basher Wraith PS and got some clean used gmade 103mm xd piggys but they have strange mismatched springs. From a re really long and rears are almost too short. I have a droop kit on my wraith and care mostly about trail cruises amd crawling. What spring are recommended for this? Soft gmade 58mm springs or ??? Thanks for any suggestions. Pics a plus Jon |
03-25-2014, 10:34 AM | #2 |
Pebble Pounder Join Date: Dec 2009 Location: Vancouver, WA
| Re: Which springs for Gmade xd piggys |
03-25-2014, 11:46 AM | #3 |
I know that, but which? Soft, med, hard?
03-25-2014, 12:24 PM | #4 |
That depends on a few different things, if your rig is stock try the soft ones. The reason I posted a reply was you had mentioned the 58mm and I wanted to point out the 103mm shocks are 68mm springs. I have been trying to figure out in the last few days which springs come with the shocks, no luck. Mine do not seem to have a color marked on them like the ones on RPP's site, but I would assume they come with mediums based on what I have read so far. I was just going to order the soft springs and try them out. You don't necessarily have to use gmade springs either, here is a post on rcshortcourse of some folks trying different springs. Gmade XD Aeration shocks - RCShortCourse |
03-25-2014, 07:48 PM | #5 |
Ok, right. I checked their site this morning and figured out 68mm was what I needed. I ended up ordering softs and a pair of medium to see what works for me. Thanks for the Link, seems some other springs will fit if I'm unhappy with the glades after playing with them. Thanks for your time |
03-25-2014, 09:19 PM | #6 |
Pebble Pounder Join Date: Feb 2004 Location: Born in a crossfire hurricane
I'm using Proline rear slash shock springs on my 103mm g-made piggybacks. They work great and the soft set is softer then the g-made springs. I'm even using the slider that allows you to use the second tender spring. There are pictures posted in the g-made section. And yes, both brands of springs are marked so that you can keep the stiffness strait. Proline sells a spring assortment, soft, med, and hard.
03-26-2014, 10:26 AM | #7 |
03-26-2014, 11:24 AM | #8 |
Sorry, no. I had to buy the rebuild kit, cheapest on flee-bay, so you'd need two spring assortment sets and two rebuild kits for the sliders. I'm sure they would be easy to machine from delrin but I don't have access to a lathe. I even looked for a PVC or urethan tubing option with no luck. But buying the rebuild kit is a pain for just the two plastic parts.
03-26-2014, 12:28 PM | #9 |
Rock Crawler Join Date: May 2012 Location: Minneapolis
I've also used T-maxx red and slash progressive springs. Depends on the setup you want. As stated above, the Proline powerstroke for slash rear springs fit. You either need the spacer to run the 2 stage, or just move the adjustment collar down and run the larger proline spring.
Which springs for Gmade xd piggys - Similar Threads | ||||
Gmade piggys | Straxus | Axial Wraith | 10 | 02-02-2014 10:20 AM |
Need help with springs for Gmade shocks on my Wraith | NCT_Guy | Axial Wraith | 12 | 01-07-2014 09:20 AM |
Gmade piggys or icon? | Beej | Axial SCX-10 | 13 | 08-03-2013 10:29 AM |
Gmade piggyback XDs springs | cytogen | G-Made Crawlers | 25 | 03-20-2013 12:25 PM |
