03-28-2014, 05:25 PM | #1 |
Quarry Creeper Join Date: Feb 2011 Location: Litchfield park
| Any ideas on getting better incline abilites?
I'll start with my current setup: RTR Wraith Axial Universals Aluminum Chubs Aluminum Knuckles Axial Rockster Beadlock Proline TSL 2.2's (weighted 2.75oz each ft. 1oz each rr) additional stick weight on the axle (.5oz ft. .25 rr) Stock shocks and springs in droop setup about .5 inch Battery up front Servo winch up front 3six Aluminum seats Am I about at the limit of this truck? Right now I'm getting about a max of 58-60 degrees based on my phones angle finder. |
03-28-2014, 05:47 PM | #2 |
Quarry Creeper Join Date: Sep 2011 Location: Lexington
Overdrive gears up front, and/or under drive gears in the rear. Flip the shock mounts to lower the suspension. Just a couple more options.
03-28-2014, 05:52 PM | #3 |
RCC Addict Join Date: Oct 2011 Location: Brighton UK
| Re: Any ideas on getting better incline abilites?
As above flip the axle shock mounts so they lower the car. I'm also running 100mm king shocks and sat neutrally my lower links are parallel to the ground, I think it performs great. Last edited by northernerbill; 03-28-2014 at 05:55 PM. |
03-28-2014, 06:04 PM | #4 |
Newbie Join Date: Jul 2013 Location: Moranbah, AUST
Hi guys, can someone please take a pic of the flipped axle shock mounts? Cool truck |
03-28-2014, 06:07 PM | #5 |
RCC Addict Join Date: Jan 2011 Location: Razorback Haven
Get the duuuuuuuude upper link mounts. This will help you link geo! |
03-28-2014, 06:23 PM | #6 |
what size battery are you running up front? you could definatly do more weight in your wheels. especially with the plastic rims. also get DCW (Duuuuuuuuuude) link risers. and third if those two don't work do a smaller battery. are you flipping over backwards or you just cant drive up a steeper slope? the fix can be vastly different for each. and trades offs to be able to do one better than the other. suggestions above are for flipping over backwards. eventually you get to the point you cant outrun gravity. |
03-28-2014, 07:01 PM | #7 |
| Re: Any ideas on getting better incline abilites? I've thought about under drive in the rear but wouldn't that make my decent suffer? I have to go back down the same slopes I went up to get back to my car.
03-28-2014, 07:05 PM | #8 | |
| Re: Any ideas on getting better incline abilites? Quote:
I am flipping backwards. I'm trying to just keep the front end down. These tires are amazing. | |
03-28-2014, 07:06 PM | #9 |
| Re: Any ideas on getting better incline abilites? |
03-28-2014, 07:16 PM | #10 |
Rock Crawler Join Date: Nov 2011 Location: clarksville,ar
Going overdrive up front and underdrive in the back, or just overdrive up front alone, would help a bunch with the flipping over.. I had od/ud in an scx unimog and It worked amazing...totally solved my flippong issues... the underdrive in the rear shouldn't affect your decent at all... I never noticed any ill effects from having it...
03-28-2014, 07:18 PM | #11 |
| Just unbolt your shock from the axle along with the lower link...and take that little mount off and turn it upside down...then bolt it back on and hook up the shock and link and bam!!! Ur done...
03-28-2014, 07:19 PM | #12 | |
03-28-2014, 09:17 PM | #13 |
ok then you need to do the 3 things I mentioned more front weight. fix anti squat (CDW link risers) and smaller battery (mega top heavy with that brick battery) you will see vast improvements. |
03-28-2014, 09:51 PM | #14 | |
What exactly do the link risers do? Won't they mess up the axle angles? | |
03-29-2014, 02:49 AM | #15 |
Just read your first post again and the 60 degrees part. Apart from your truck handling better generally with all the above mods I doubt you will get anymore capability on any incline steeper. At that kind of angle it's easier for the the rear axle to rotate and the wheel stay still flipping your car. I bet if you removed all the weight from the wheels and axles it would behave the same. |
Any ideas on getting better incline abilites? - Similar Threads | ||||
Incline | Skier | Venom Creeper | 1 | 04-03-2011 07:25 PM |
???Won't Hold On Incline??? | Justinaskin | Axial AX-10 Scorpion | 17 | 10-10-2010 02:15 PM |
Incline board | dmcchaser | Newbie General | 5 | 06-19-2010 12:02 PM |
New incline | JCO245 | Losi Mini-Rock Crawler | 5 | 03-02-2010 01:45 AM |
problem when going up incline | xnonox | HPI Wheely King | 6 | 07-06-2007 09:47 PM |
