03-30-2014, 06:51 PM | #1 |
RCC Addict Join Date: Mar 2013 Location: Commerce Township
| Tra-Wrexo
With all the incredible, high quality builds in this forum, and with my addiction taking over again, I have developed the need for a IFS version of the Wraith. Nothing new I know, but but reading and observing some of the projects here, I felt I wanted to share mine. I had an issue, with king pins, just a personal thing, nothing against the stock Exo suspension, but Ii had seen a UK builder use the Traxxas Slash 4x4 front A arms and hubs and It looked pretty bullet proof. Hence "Tra-Wrexo". Also wanted to paint the next project so here It goes. Sure the yellow won't hold up well but for now it's a departure from black. Axial Wraith, Tra-wrexo, Scx10/GMADE?Summit "blend"/Xray T2/Sakura Zero/Vaterra Kemora. [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] |
03-30-2014, 07:02 PM | #2 |
Rock Crawler Join Date: Jan 2008 Location: Lehigh Valley, Pa
The yellow looks nice. I'm working on perfecting one of hear as well. Keep it up
03-30-2014, 07:54 PM | #3 |
RCC Addict Join Date: Dec 2012 Location: Crookston
Looks like a nice start.
03-30-2014, 08:05 PM | #4 |
Newbie Join Date: Jun 2006 Location: Wesley Chapel
| Re: Tra-Wrexo
I like the yellow
04-03-2014, 06:49 AM | #5 |
| Re: Tra-Wrexo |
04-05-2014, 11:41 AM | #6 |
| Re: Tra-Wrexo |
04-05-2014, 04:43 PM | #7 |
I wanna be Dave Join Date: Feb 2007 Location: BFE, NV
| Re: Tra-Wrexo
What front shafts are those?
04-06-2014, 08:37 AM | #8 |
| Re: Tra-Wrexo
Integy Slash 4x4 units. P/N is T8528, I had to clearance the a-arm slightly so as to gain steering clearance just behind the hub/carrier unit, back side of the a-arm. I also had to lock the diff via a section of round steel so I could use the Integy outdrives. So now the front diff is locked. Hope this helps. Here is a current pic from yesterday. [IMG][/IMG] |
04-06-2014, 10:44 AM | #9 |
| Re: Tra-Wrexo
Pictures of full steering lock?
04-06-2014, 05:19 PM | #10 |
| Re: Tra-Wrexo |
04-08-2014, 02:55 PM | #11 |
| Re: Tra-Wrexo
I wanted to add a quick update since posting the last set of photos, it seems that the left side dogbone was barley inserted into the outdrive cup. I had a couple of options, since I made the "locker shaft" it seems I should have added 4 to 5mm more overall width to the assembly. Since I was heading out of town for the week I needed to address this before I left or it would drive me nuts till I returned. I relocated the hub carrier lower pivot shaft (outer) inboard 5mm. Removed a little material from the a-arm and it seems to work perfectly. I may still opt for a re-do of the locker shaft but I wanted to see how all these parts work before I tear it all down again. If anyone needs a photo I can send them when I get back Friday evening.
04-12-2014, 09:17 AM | #12 |
| Re: Tra-Wrexo |
Tra-Wrexo - Similar Threads | ||||
my wrexo | Frakke | Videos! | 5 | 08-27-2013 12:27 AM |
