MIP's on wraith if I add a long drive hub part no MIP11117 will it clear my spur gear cover with out trimming it ?? I have the AX10 shafts |
Re: MIP's on wraith Yes. "thumbsup" Just a FYI if you didn't already know, you can use these Traxxas Screw Pin 4x15mm Revo (6) to attach those ax10 shafts to the other side of the tranny and the axle outputs. |
Re: MIP's on wraith Thanks and yes I have the traxxas pins, the rear shaft is in. |
Re: MIP's on wraith The MIP11117 still use the smaller Wraith sized pin. Mine cleared the cover when installed, but every tiny rock and stick got jammed in there. Had to trim the cover a bit to keep my sanity |
Re: MIP's on wraith Im using the AX 10 mips and had to trim a little but it gives you a bigger pin and they are cheaper. |
Re: MIP's on wraith Quote:
http://s3.postimg.org/fy0gjrt37/IMG_20140409_125716.jpg |
