04-15-2014, 05:09 AM | #1 |
Newbie Join Date: Feb 2014 Location: St. John's
| Ordering a battery today, need a quick bit of help.
Hey all, just built my Wraith kit. I have ordered the Mamba Max ESC, Tekin Pro4 3300KV motor, Castle BEC 10 Amp BEC,Solar D771 Servo. Whats the best battery to run in this thing? Gonna be trail running/bashing with the odd little bit of crawling......I was thinking like a turnigy 5000 3S 25C?? I don't have any lipo's yet in my other rig, so if any of you knew of a package deal with batt and charger that would be good as well. This thing hasn't moved under its own power yet, and its already a money pit. Really enjoyed the build though, better then watching the voice with the wife!!! Thanks! |
04-15-2014, 05:53 AM | #2 |
| Re: Ordering a battery today, need a quick bit of help.
Are you running 32 pitch spur & pinion? You'll need to with that much power. I recommend the smallest p pinion (11t I think) and largest spur you can fit. Keep in mind, a large battery lime the 5000mah will decrease performance because it is so heavy high up on the truck. A 2200mah or 3300 should still give you plenty of run time imo... up to you though. Obviously, you will need multiple 2200's to ge t the same run time as the 5000. Also, that's a hungry motor, go for at least 30c/40c with 60c being better. |
04-15-2014, 09:14 AM | #3 |
Newbie Join Date: Jan 2014 Location: Aspen
the highest C rating you can afford. I have some 60c 3s and boy do they rip compared to another 3s at a 30c rating.
04-15-2014, 02:07 PM | #4 |
Newbie Join Date: Oct 2013 Location: steep falls
does a higher C rating use up that battery faster?
Ordering a battery today, need a quick bit of help. - Similar Threads | ||||
bit of a battery issue? | SwampDawg | Electronics | 11 | 10-02-2012 03:59 PM |
Ordering Today! | Lightninn | Axial Wraith | 1 | 12-07-2011 01:52 PM |
Ordering a Castle BEC. Quick ? | the02stangman | Electronics | 6 | 08-31-2009 01:51 PM |
quick bit of help? | dhyde79 | Axial AX-10 Scorpion | 2 | 07-02-2009 10:09 AM |
Couple quick pics from today | slugzracing | Chit Chat | 7 | 09-17-2006 04:21 PM |
