Thread: Knuckle Busters 1.9 Wraith
Old 05-11-2014, 08:15 AM   #21
Default Re: Knuckle Busters RTR Wraith
Anybody run their Crawlmaster or other motor with any timing? I'm just curious what the pros and cons would be?
KBR97 is offline   Reply With Quote
Old 05-11-2014, 08:24 AM   #22
I always ran the recommended timing advance from holmes hobbies site...
*6 degrees of timing advance is popular and will not adversely affect motor life
allanon1965 is offline   Reply With Quote
Old 05-11-2014, 08:42 AM   #23
How does it benefit the motor or the performance of the vehicle? More power, faster, run more efficient?
Old 05-12-2014, 05:42 PM   #24
Stripped out the stock servo horn today. I guess a savox and vp steering will do that lol.
Old 05-16-2014, 11:02 AM   #25
Axial aluminum servo horn showed up today, along with the posts to keep the hood secure. I played around with some magnets a but I just didn't come to a setup that I was pleased with.
I also have a dynamic concepts rubi body coming. I have a wrangler as my daily driver/weekend crawler so I would like to paint it and set it up as close to the 1:1 as possible. I'll probably go with the 8 hole mickey thompson wheels to match. And I would like to make a small stubby bumper to match as well.
I have read that the testors model paint may crack on lexan bodies because of flex. Do you think I would be ok just to do the front fenders and the grill black?
Old 05-20-2014, 10:56 AM   #26
I like to use Lexan paint for all Lexan body surfaces, just to be sure of adhesion.
Dynamic Concepts is offline   Reply With Quote
Old 05-24-2014, 06:27 PM   #27
Ok sounds good. I'll grab a can of black for the grill and fenders.
Old 05-24-2014, 06:29 PM   #28
Took a trip with the family up to my fathers weekend getaway house in Massachusetts. There is a nice river across from his property that has some real nice rocky banks when the water isn't real high. Did some trail running along the river and then some crawling down on the rocks.
Old 06-04-2014, 06:06 PM   #29
Guys if you don't mind, take a look at my thread in "paint & body". Having a little trouble with my new body. I'm sure scissors and a Dremel will fix it but I'm trying to keep as much body as possible...
Having trouble with dynamic concepts body.
Originally Posted by LockedupTJ View Post
Looking good!
Thank you!
Old 06-06-2014, 06:01 PM   #30
I think I got the problems with the body all worked out. Almost ready for paint.
Old 06-17-2014, 10:53 AM   #31
Body is all painted and mounted. Came out pretty good!
Old 06-23-2014, 03:36 PM   #32
Tranny gear stripped out today. Guess its time for an upgrade.
Old 06-23-2014, 07:46 PM   #33
RRP
By the way it's Justin(UndefinedTaco) from Pirate..
Sent from a whiskey downer beer pounder's shop
Undefined is offline   Reply With Quote
Old 06-24-2014, 04:58 AM   #34
What's up man, I figured that by the name.
I'm looking into hot racing gears. Harley used them in his budget build and stated that they work very well despite being hot racing. I'll order something by the end of the week whether it's RPP Or Hot racing.
Old 06-24-2014, 05:13 AM   #35
Looking good! I just built one just like that in green lol. The body is a pain to get right but it comes out nice. What part of ma is that? Looks like a good spot.
Jcplante is offline   Reply With Quote
Old 07-25-2014, 07:34 PM   #36
Need some tips on a problem I'm having tonight. I plugged a battery in to make sure everything was good to go for tomorrow. I noticed that its acting like it lost bind for some reason? When I powered it up I get the blinking lights and constant beeping from the ae2. I plugged in the bind plug and went through the whole procedure a few times and I get nothing. Same blinking and beeping.
Edit....After trying to bind I get this
Transmitter - flashing green light
AR3 RX - solid red
AE-2 continues rapid flash and beep every second
Turn it all off, power it back up and no response.
Old 07-25-2014, 08:27 PM   #37
AR3 RX - solid red
Watch the YouTube videos for binding/calibrating...Axial does them...I ran into a similar situation a couple weeks back and discovered the calibration process much quicker than what I was doing.
Axial - Calibrating the AE-2 ESC: http://youtu.be/iGLqjs3mPE4
btango05 is offline   Reply With Quote
Old 07-25-2014, 09:14 PM   #38
I did watch those. Thats actually the first thing I did was go right to youtube to make sure of the binding procedure. I'm starting to think that maybe the problem is more then just the truck not binding. The solid red light on the AR3 should mean that bind was successful.
First thing I noticed in the "calibration" video was that there was servo response. I'm not getting any response from throttle or servo.
Old 07-27-2014, 01:03 PM   #39
Any update? Were you able to solve the problem?
Old 07-27-2014, 08:31 PM   #40
Not yet. Haven't had time to play around with it again yet. Although I am leaning towards maybe the ESC being bad. I do recall the rig getting pretty wet last time it was out.
When I go through the bind procedure the blinking light on the AR3 goes solid which is supposed to mean the bind was successful. But the AE-2 keeps blinking red/green rapidly and also has a continuous beep every 1-2 seconds. No response from throttle/reverse or steering. I'll have mess with it this week when I have some free time.
Knuckle Busters 1.9 Wraith - Similar Threads
Knuckle weights for wraith? Subytuner Axial Wraith 24 03-10-2015 02:46 PM
Wraith knuckle question Dhallmark Axial XR10 8 01-28-2014 05:12 PM
