09-04-2014, 11:16 AM | #41 |
Quarry Creeper Join Date: Mar 2014 Location: LI
| Re: Knuckle Busters RTR Wraith
I pulled all the electronics, re-soldered some stuff, and voila it works just fine now. I never understood what the actual problem was, but it's fixed. I also have a set of pitbull rock beast 1.9's on the way. What's a relatively cheap beadlock wheel that will work fairly well? I like the price and look of the Axial 8 hole beadlocks. $30 for a set seems pretty good just to get me rolling on the new tires. I'm trying to keep the look of the wraith close to my real TJ which has Cragar soft 8 wheels. |
09-04-2014, 02:08 PM | #42 | |
| Re: Knuckle Busters RTR Wraith Quote:
Cool. I like the Hot Racing 8-hole steel beadlocks for 1.9 scale and they are perfect weight. RC4WD makes some too. | |
09-04-2014, 09:52 PM | #43 |
Pebble Pounder Join Date: Jul 2013 Location: Candler
Why did you choose 1.9s over the 2.2 size. Nice looking rig matches your 1:1 nicely.
09-05-2014, 02:07 PM | #44 | ||
Switching to 1.9 for me is purely aesthetic. I really like the "scale" version of a wraith. Smaller tires, narrow axles. It just looks...right. | ||
09-13-2014, 11:01 AM | #45 |
Time for a poser shot. My tires came last week. Next I'll order wheels or maybe scx10 4 link mounts. I'm thinking about selling off all the 2.2 stuff to help fund the project. I'm just nervous about not liking the 1.9 conversion and then not having the old parts anymore. I'll have to think about it. Sent from my iPhone using Tapatalk |
11-26-2014, 10:41 PM | #46 |
Finally got around to ordering some parts for the 1.9 conversion. I got a decent deal at RPP on some brand new axles. Also grabbed some axial beadlocks, a 4link servo plate and some link ends. Mounted the tires on to the axial beadlocks. Last edited by KBR97; 11-26-2014 at 10:45 PM. |
11-26-2014, 10:59 PM | #47 |
A quick mock up of wheels and tires under the chassis. This is the wheelbase I'm shooting for. Just about 12" - 12.25 Sent from my iPhone using Tapatalk |
12-22-2014, 06:01 PM | #48 |
Alrighhhty then! The 1.9 conversion is basically done. I worked on it a little bit over the past few weeks and just had it outside for a shakedown run. Suspension cycles smooth as far as I can tell. Wheel base is 12". I used a STRC 4 link servo plate for the front axle. Beware when using this plate and a Savox servo. The larger length of the servo box covers the link mounting holes. I drilled two new mount holes for the servo and it was perfect. I had to remove the upper bumper mounts to let the servo clear the framework when the suspension moves. I stiffened up the frame with one of those little aluminum links from axial. The only other problem I ran into was the rear shocks rubbing on the frame. I used a combination of some Dremel work and also some spacers between the shock and the upper mounts. Here's a bunch of pics of it just sitting on the table inside. Sent from my iPhone using Tapatalk |
12-22-2014, 06:02 PM | #49 |
| Knuckle Busters RTR Wraith Sent from my iPhone using Tapatalk |
12-22-2014, 06:04 PM | #50 |
| Re: Knuckle Busters RTR Wraith Almost passed the beer can test. Lifted the rear a tiny bit. Sent from my iPhone using Tapatalk |
12-23-2014, 12:00 PM | #51 |
Just for comparison... New wraith - Now I need to drop the front down a little. Sent from my iPhone using Tapatalk Last edited by KBR97; 12-23-2014 at 12:02 PM. |
12-28-2014, 05:34 PM | #52 |
Making some new panels. These are going to be beater panels. They are made from real thin metal flashing that will bend and dent pretty easy, hopefully. Most of the panels came out pretty decent. The hood is...meh. It's not horrible. Sent from my iPhone using Tapatalk Last edited by KBR97; 02-08-2015 at 08:05 AM. |
12-28-2014, 05:36 PM | #53 |
Rock Crawler Join Date: Nov 2013 Location: In the country
Cool
12-28-2014, 07:15 PM | #54 |
Painting them primer grey, then a top coat of flat green. I'm also painting the RTR hood just so I can switch it out if I choose to. Sent from my iPhone using Tapatalk |
12-28-2014, 08:19 PM | #55 |
Done for now. I'm going to redo the side panels to make them full length and wrap the rear corner. First time I did them the measurement was not right so I cut them real short for now. Here they are all painted and mounted. I'll run the jeep hood for now. My own hood doesn't look that great. Sent from my iPhone using Tapatalk Last edited by KBR97; 02-08-2015 at 08:07 AM. |
12-29-2014, 12:33 PM | #56 |
Brought it out for some rocks and dirt. Performed great! Sent from my iPhone using Tapatalk Last edited by KBR97; 02-08-2015 at 08:09 AM. |
01-03-2015, 10:42 PM | #57 |
Another quick update... Here's the latest set of metal panels that I made. Not crazy about this hood either, but I stripped down the jeep hood and repainted it orange. Oh and I have a Mamba Max Pro, a Holmes Hobby brushless Trailmaster motor, and some gears on the way. Sent from my iPhone using Tapatalk Last edited by KBR97; 01-03-2015 at 10:50 PM. |
01-04-2015, 04:28 PM | #58 |
Working on making a scale fuel cell. Hopefully it works out like planned. I was fiddling with it for a while. Ended up using all different parts I had laying around. Made the box out of hobby wood, wrapped it with metal flashing then glued it all together. Used a wraith shock part, some fittings and tube from a fish tank filter and some picture hanging wire . Sent from my iPhone using Tapatalk |
01-04-2015, 07:07 PM | #59 |
Got it all together and mounted to the rear panel of the truck. Hopefully it all stays together. I used a combination of gorilla glue to hold all the little parts together, wood glue for the wood frame, and finally hot glue to hold the fuel cell to the panel. Sent from my iPhone using Tapatalk Last edited by KBR97; 02-08-2015 at 08:10 AM. |
01-06-2015, 07:20 PM | #60 |
When you guys buy the metal tubing to put on your custom links what exactly are you buying? And also where is it typically found. I tried 2 different auto parts stores and a hardware store. Haven't found any yet.
Knuckle Busters 1.9 Wraith - Similar Threads | ||||
Knuckle weights for wraith? | Subytuner | Axial Wraith | 24 | 03-10-2015 02:46 PM |
Wraith knuckle question | Dhallmark | Axial XR10 | 8 | 01-28-2014 05:12 PM |
