04-17-2014, 10:16 PM | #1 |
Quarry Creeper Join Date: Dec 2013 Location: Central IL
| What's the difference between pro4 & roc 412
Can someone enlighten me? I've been running the Pro4 3100 in my wraith and love it..However after having to upgradmy brothers wraith build..I u took my pro4 out and put it in his. So I bought a roc 412 3100 kv for my wraith. Be here Monday. Sent from my SCH-I545 using Tapatalk |
04-17-2014, 11:19 PM | #2 |
| Re: What's the difference between pro4 & roc 412
pm Ty@Tekin on here...he can tell you what the difference is!
04-17-2014, 11:31 PM | #3 |
Newbie Join Date: Sep 2011 Location: Gilbert
I have both, from what I gather the Pro4 has the 5mm shaft and the Roc is designed for more low end torque. The Roc is based on the Pro4. The Roc for sure has great low end and is no slouch on the top end either.
04-18-2014, 02:08 AM | #4 |
Rock Crawler Join Date: May 2012 Location: Minneapolis
Ty at tekin has said on other threads that they are essentially the same thing (except the kv and pinion size obviously). There are some tweaks for low end speed control but essentially the same. Dna |
04-18-2014, 06:40 AM | #5 |
Cool. So the roc does or does not have a 5mm shaft? Sent from my SCH-I545 using Tapatalk |
04-18-2014, 07:32 AM | #6 |
the roc does not have the 5mm shaft..
04-18-2014, 09:06 AM | #7 |
Newbie Join Date: Jan 2014 Location: Aspen
you can use the pro4 rotor on a 412. its about $55 last time i looked. problem I've herd is you can only run/fit and 11t pinion with the 5mm shaft. big strength gain but huge gear tuning loss. only seen one guy break the standard 412 shaft to.
04-18-2014, 09:16 AM | #8 |
Quarry Creeper Join Date: Jan 2014 Location: Springfield
| Robinson Racing makes a pretty good assortment of 5mm pinions now. I run a 14 tooth on mine.
04-18-2014, 09:58 AM | #9 |
Cool. I'll stick with 412 shaft. I'm sure it'd be fine. Plus I have about 6 different 32p robinson pinions to go with the Gen3 slipper. Sent from my SCH-I545 using Tapatalk |
04-18-2014, 10:08 AM | #10 |
I put my pro4 3100 in my brothers wraith and took it out for test run. All metal tranny. Mips shafts and VP links and wheel axle parts. TSL 2.2 swampers. All electronics are under the hood. Hill climbs really well.
What's the difference between pro4 & roc 412 - Similar Threads | ||||
Roc 412 vs pro4 hd | cneill24 | Electronics | 30 | 11-26-2014 08:05 AM |
Tekin Pro4 vs. Roc 412 | crawler nut | Electronics | 51 | 05-04-2014 09:14 AM |
Roc 412 3100kv amp draw | Bogncrawl | Electronics | 3 | 12-27-2013 08:10 PM |
