04-26-2014, 01:26 AM | #21 |
RCC Addict Join Date: Aug 2007 Location: Seattle
| Re: Another 1.9 Wraith
Happier with the ride height and links are close to being finalized. 3.5" full droop 2" stuffed 2.5" at ride height |
04-26-2014, 05:09 AM | #22 |
Rock Crawler Join Date: Feb 2011 Location: Spur, TX
Looking good. You planning to leave the rear cage like that, or got something else in mind? After your previous pictures I'm considering running mine without a front bumper, and adding vertical bars to the top rear of the cab straight to the frame for a pickup style cab / bed instead of a fastback.
04-26-2014, 07:19 AM | #23 |
Pebble Pounder Join Date: May 2008 Location: Two Harbors, MN
| Re: Another 1.9 Wraith |
04-26-2014, 09:46 AM | #24 |
Cage will end at the farthest shock mount so a spare tire fits like I want. I'll probably rough that out today.
04-26-2014, 11:09 AM | #25 |
Newbie Join Date: Dec 2013 Location: Menlo Park
Really digging this build! Good job. I'm assuming you have to use shorter shocks with the tummy tuck? |
04-26-2014, 12:14 PM | #26 |
The axle to chassis height didn't change. Just the angle of the links and drive shaft so I'm gonna run full length rears and two stock shims in the front.
04-26-2014, 06:49 PM | #27 |
Ran out of threaded rod and lost a wheel/ tire but this is the plan for the back. Bought losi whites in 2.75" and wishing I went with 2" Other than that it flexes ok. |
04-26-2014, 09:16 PM | #28 |
I have no intentions of running the axial interior. Does anyone know the dimensions of the Apache c1 or a pic of one used in a wraith?
04-27-2014, 10:36 AM | #29 |
Quarry Creeper Join Date: Jan 2013 Location: Spokane
Are those the shorter big bores? BuIlT nOt BaUgHT! |
04-27-2014, 10:53 AM | #30 |
4" eye to eye. Sorry.
05-02-2014, 12:52 AM | #31 |
Measured the shocks again and they are 4" Had to kick it old school and bend some brake line and all thread with a brick and a hatchet. Trying to rig this thing up enough to compete this Sunday. Here's the current setup. It's the best I can do without tubes. Found some binding in the upper/ front links so that'll get squared away tomorrow. |
05-03-2014, 12:27 AM | #32 |
Test drive went ok. Not happy with the rear spring lenght so I'll be running a limiter strap as a quick bandaid. Picked up a 5000mah 3s 35c pack and things were going good until the bec quit working. Gonna throw more parts at it tomorrow. |
05-03-2014, 05:48 AM | #33 |
Newbie Join Date: Apr 2014 Location: Summerville
I love the burnt orange. The doors of look with exposed roll cage is pretty sick too.
05-07-2014, 10:24 AM | #34 |
Got my ass handed to me on our first comp after taking a repair. Things I learned: Loctite everything Dont comp with a 5000 mah pack 5 pound scaler isn't impossible Balanced weight from front to back is great. |
05-09-2014, 09:28 AM | #35 |
Quick update. Was having some glitching with my setup. Full throttle would result in full lock right with my servo. Here's what I did to fix it and a list of radio gear. 3pk with fasst spektrum Spektrum micro rx Y-harness with only the power wire removed on the male side Spektrum rx capacitor Tekin rs Tekin 17.5 3s Solar d772 Cc bec |
05-09-2014, 01:19 PM | #36 |
Quarry Creeper Join Date: Jul 2010 Location: Where Jeep axles are made
Did you remember to locktight everything Glad you fixed the gliching, now we can all watch you win the next comp |
05-09-2014, 02:40 PM | #37 |
Yep. Right after I read your reply. I gotta learn to drive before I think about winning. This thing is way faster than I thought it would be. I guess I could try a 2s but fawk that. |
05-09-2014, 09:24 PM | #38 |
Fried another bec. I'm 3 for 3. Three different solar servos and three different becs. |
05-09-2014, 10:52 PM | #39 |
how are you wiring up the BEC? are you running 2 servos off of one BEC?
05-09-2014, 11:11 PM | #40 |
One servo Power and ground soldered to tekin rs esc 3" Y-harness with heavy gage wire Male connector has been used with a signal wire as well as ground Female connectors go to the servo and bec Tried removing the signal wire on the bec side of the harness and it didn't change anything First bec was set at 7.4v Second bec was set at 7v Third was set at 6v Tried a new servo each time a bec quit Endpoints were at a safe spot Batteries were all new 1000mah 2100mah 5000mah Last edited by djjiz; 05-09-2014 at 11:19 PM. |
Another 1.9 Wraith - Similar Threads | ||||
Wrath problem? | Browner93 | General Crawlers | 3 | 11-18-2013 06:36 PM |
