04-21-2014, 12:45 PM | #1 |
Quarry Creeper Join Date: Dec 2013 Location: Central IL
| What most likely to break next?
With Steel tranny gears, Slash 32p slipper and MIP Shafts. VP on all 4 corners and 3100 Pro4/MMP, what is the next breaking point in the wraith on 2s/3s? Is the axle shafts or gears next to break or the axle case?
04-21-2014, 12:49 PM | #2 |
Rock Crawler Join Date: Mar 2012 Location: UK
| Re: What most likely to break next?
Gears, lockers and or pinion bearings
04-21-2014, 03:01 PM | #3 |
So I need heavy duty gears. What lockers are best? And you motor pinion bearing? Sent from my SCH-I545 using Tapatalk |
04-21-2014, 03:10 PM | #4 |
RCC Addict Join Date: Mar 2013 Location: Oklahoma City
He is referring to the axle pinion bearing needing to be converted to a bushing so it last much longer with that sort of power in it. Anything in the drive line is subject to a beating and can fail next. But, if it were me, I would want an inexpensive fail point. You're not going to bulletproof everything - something is bound to break or twist. |
What most likely to break next? - Similar Threads | ||||
how do you break so much??? | muddinscx | Chit Chat | 29 | 05-08-2015 06:24 PM |
What will break first | AdventureIQ | Axial SCX-10 | 11 | 09-27-2013 07:44 PM |
is neutral break the same as drag break? | rod-211 | Newbie General | 3 | 02-25-2011 08:33 PM |
A New Break | twisted | General Crawlers | 0 | 06-17-2006 01:49 PM |
Wanted to break it in... Not break it! | Spoon | Tamiya TLT Crawlers | 8 | 08-30-2005 06:55 PM |
