RPM Stage Three Slipper Clutch OK can I put the Robinson Racing Stage Three Slipper Clutch on the stock top shaft? :???: I will eventually upgrade to the Super Shafty top shaft. |
Re: RPM Stage Three Slipper Clutch RPM?? do u mean Robinson racing? |
Re: RPM Stage Three Slipper Clutch If its the robinson one its looks to be a direct replacement and should use the stock top shaft...the super shafty one is made specific for the Slash 2wd metal slipper |
Re: RPM Stage Three Slipper Clutch RRP part#1545 fits the stock Axial top shaft. The metal spur gear is 80T/48p Robinson Racing Products - Products and Pricing for Axial Wraith |
Re: RPM Stage Three Slipper Clutch I have the Robinson Racing Products 7856 Slash High Performance Slipper Kit 32 Pitch |
Re: RPM Stage Three Slipper Clutch Then you will need the shaft from Super Shafty. |
Thanks |
