04-26-2014, 10:52 AM | #1 |
Quarry Creeper Join Date: Dec 2013 Location: Central IL
| MMP and 3s
Do you have to do anything special to run 3s on the MMP? I have a small pack I want to try and see how much different 2s is to 3s. I have Alls still drive train btw. Sent from my SCH-I545 using Tapatalk |
04-26-2014, 10:57 AM | #2 |
RCC Addict Join Date: Oct 2012 Location: Norcal
| Re: MMP and 3s
Plug it in and run it! Beware though, once you go 3s you wont go back.
04-26-2014, 10:58 AM | #3 |
| Re: MMP and 3s
You just need to have the lipo cutoff set to auto or 3s. If you use auto its a good habit to listen to the startup chimes and make sure the correct cell count is heard.
04-26-2014, 11:00 AM | #4 |
| Re: MMP and 3s
Bingo. I was editing my post, lol.
04-26-2014, 03:23 PM | #5 |
Wow. Ya 3s IS bad. So how would 3s 30c compare to a 2s 70c? Would it be close in performance? Sent from my SCH-I545 using Tapatalk |
04-26-2014, 03:26 PM | #6 |
Rock Crawler Join Date: Feb 2011 Location: Spur, TX
| Re: MMP and 3s
I'm new to the lipo setup myself, but I'm loving 3s so far. 3s, 20c 5000mah lipo Mamba Max Pro Pro4 3300kv AX2 2 speed trans When in basher mode it gets up and goes! If not for the rear sway bar the torque twist would be an issue. Crawler mode is great, got plenty of power to get over obsticles and up hills when needed. |
04-26-2014, 03:30 PM | #7 |
| Re: MMP and 3s
I just put 3s in my DMG Stiffy rig...wow! I like it with the 13.5 tekin!
04-26-2014, 03:52 PM | #8 |
RCC Addict Join Date: Mar 2012 Location: Under a Rock in North Texas
| Re: MMP and 3s
Y'all are making me want to spend money on a 3s battery now......
04-26-2014, 04:24 PM | #9 |
| Re: MMP and 3s
it definately wakes them up!
04-26-2014, 04:45 PM | #10 |
| Re: MMP and 3s |
04-26-2014, 06:02 PM | #11 |
Damn. The reality of running BL is you have to your wraith built solid with metal and aluminum from motor to the wheels to somewhat ensure no breakage. Sent from my SCH-I545 using Tapatalk |
04-26-2014, 06:49 PM | #12 |
| Re: MMP and 3s When you start getting into the more powerful motor / esc setups there is no guaranteed build for no breakage. You build it as tough as you can, go easy on the throttle if you get a tire or something bound up.
04-26-2014, 07:31 PM | #13 | |
| Re: MMP and 3s Quote:
My wraith is pretty well built but the 3656sd on 4s will break parts at a moments notice. You have to be very careful if there is any chance of a bind. Its well worth it though. Seeing the tires stretch into pizza cutters on the dirt climbs is pretty awesome. | |
04-27-2014, 06:52 AM | #14 |
Bent the front left axle. Not on 3s just 2s. The outer shaft already had plenty if wear on it so it was just a matter of time. Order some universals and some HD gears and VP diff lock. Sent from my SCH-I545 using Tapatalk |
04-27-2014, 07:56 AM | #15 |
| Re: MMP and 3s
Yeah I sheared the flange of the left rest axle on mine on 2s. Was the Axial redesigned one too. Took the original one and dremmeled the flange down a bit and it works fine for now. Will look into an upgrade later. BL breaks rigs.
04-27-2014, 09:29 AM | #16 |
So are the universal ones better? I hope. I just ordered some. I suppose at least they eliminate the rest axle set up. Are the VPS the best you can get? Sent from my SCH-I545 using Tapatalk |
04-27-2014, 09:30 AM | #17 |
And I'm sticking with 2s. Sent from my SCH-I545 using Tapatalk |
04-29-2014, 08:45 PM | #18 |
So ARE the universals better and stronger? Are the VPs the BEST? Sent from my SCH-I545 using Tapatalk |
04-29-2014, 09:30 PM | #19 |
| Re: MMP and 3s
Running the RC4WD Extreme Duty XVD Axles in my Wraith. Pretty nice upgrade over stock so far, but I dont have much run time on them yet.
04-29-2014, 10:04 PM | #20 |
| Re: MMP and 3s |
MMP and 3s - Similar Threads | ||||
CC mmp vs mmp sct edition? | mudd_slinger | Electronics | 5 | 06-05-2013 01:18 PM |
Anyone using mmp? | tklatti | Vaterra Twin Hammers | 10 | 02-15-2013 01:53 AM |
Mmp vs rs | losikid | Electronics | 46 | 10-30-2011 10:36 PM |
