05-05-2014, 12:10 PM | #1 |
Newbie Join Date: Apr 2014 Location: United Kingdom
| Signal interference with metal panels
I recently made and fitted some metal body panels to my wraith but seem to be getting interference between the transmitter and the receiver. The car moves then jolts, cuts in and out and jerks about, almost as if im on and off the throttle. When I put the stock lexan panels on, all is fine. Has anyone else come across/overcome this problem? Nathan |
05-06-2014, 03:00 AM | #2 |
Quarry Creeper Join Date: Jan 2011 Location: vincennes 2 hours south of indianapolis
| Re: Signal interference with metal panels
Never heard of that. Where is your rx located.
05-06-2014, 09:18 AM | #3 |
It is located under the hood panel in the stock receiver box. Been running the lexan panels all weekend with no problems whatsoever.
05-07-2014, 08:17 AM | #4 |
Newbie Join Date: Jul 2013 Location: Orie-gone City
I have made all my panels out of aluminum and have never had a problem with interferance.. what kinda of receiver?
05-07-2014, 11:53 AM | #5 |
Pebble Pounder Join Date: Feb 2004 Location: Born in a crossfire hurricane
Another issue could be that your metal panels are grounding out to something else, another component. OR -I've also had the antena wire fall/break off at the receiver. You might check there for an intermittent short.
05-07-2014, 02:48 PM | #6 |
Cecked the panels and they dont seem to be touching any other electrical items. Im running a Spektrum DX3C transmitter with the SR300 that came with it. Been out for 2 hours tonight in the same place i get the interference and the car was running perfect. Might have to stick with the lexan panels. Nathan |
05-07-2014, 03:02 PM | #7 |
Have you tried repositioning the antenna? Sent from my SCH-I545 using Tapatalk |
05-07-2014, 03:11 PM | #8 |
Rock Crawler Join Date: Nov 2006 Location: Holland
Steel body panels?
05-07-2014, 03:12 PM | #9 |
Not yet. The antenna wire is only about 3 inches long.
05-07-2014, 03:12 PM | #10 |
Aluminium panels.
Signal interference with metal panels - Similar Threads | ||||
sheet metal panels ~ how do i get it too rust? | SwampDawg | Paint and Body | 10 | 11-05-2012 10:14 PM |
interference help - all metal mounting points... | BlueMonster | Electronics | 4 | 09-29-2006 05:59 PM |
