05-08-2014, 08:20 AM | #1 |
Quarry Creeper Join Date: Dec 2013 Location: Central IL
| Help with stiffining the cage after mod
I did the typical FB mod on the Bronco. But now the GM piggy backs when compressed, flex the hock mount area. Is there a good way to strengthen this area? Looking for some ideas. Also, are HD beveled gears worth buying? Do the stock ones ever break? I run Roc412 3100kv and MMP. |
05-08-2014, 03:45 PM | #2 |
Quarry Creeper Join Date: Feb 2011 Location: The underground
| Re: Help with stiffining the cage after mod
Mount a standoff in between the shock mounts
05-08-2014, 04:10 PM | #3 |
I like to ditch the stock mounts all together. Yes the stock gears fold the teeth over pretty easy if you don't have them shimmed really tight. The HD OD gears are a little stronger and the stock ratio HD gears and the UD HD gears are quite a bit stronger than the stock gears. |
05-08-2014, 07:37 PM | #4 |
Thanks fellas. I'll have to put some thought into stiffening it up. I was thinking there was a go to remedy. But that'd be no fun. Lol Sent from my SCH-I545 using Tapatalk |
05-08-2014, 08:37 PM | #5 |
RCC Addict Join Date: May 2013 Location: Forrestfield, Western Australia
An Axial 55mm post fits assuming you removed the battery tray. You'll need to either change out the coarse thread shock mount screws for fine thread though, 25mm long should do, or use the fine thread screw through one of the other mount holes your not using. |
05-09-2014, 02:38 AM | #6 |
Quarry Creeper Join Date: Sep 2013 Location: Norway
Take a look at this picture. I've also seen pics of this done with stock plastic cage. |
05-15-2014, 06:35 AM | #7 |
Nice stuff!! Sent from my SCH-I545 using Tapatalk |
Help with stiffining the cage after mod - Similar Threads | ||||
Axial rod cage mod? | Beej | Axial Wraith | 3 | 07-03-2013 10:39 AM |
Cage mod... how to... | DrDiff952 | Axial Wraith | 3 | 06-27-2013 10:34 PM |
cage mod | snohiker | Axial Wraith | 51 | 06-18-2013 11:58 PM |
Cage mod help? | o0wiz0o | Axial Wraith | 27 | 06-27-2012 09:31 PM |
UK Wraith Cage mod. | o0wiz0o | Axial Wraith | 33 | 05-14-2012 06:16 AM |
