05-09-2014, 02:01 PM | #21 |
I wanna be Dave Join Date: Apr 2004 Location: SoCal
| Re: The "Official" Fastest Wraiths on RCC thread. I remember that. That was the start of the worlds fastest RCCrawler that never materialized.
05-09-2014, 07:36 PM | #22 |
I wanna be Dave Join Date: Feb 2007 Location: BFE, NV
It seemed faster |
05-09-2014, 07:59 PM | #23 |
I felt the same way about mine lol
05-09-2014, 08:01 PM | #24 | |
| Quote: | |
05-09-2014, 08:02 PM | #25 |
Quarry Creeper Join Date: Jan 2014 Location: Springfield
Will the Pro4's take a 4s? I just looked it up. The one I have, the 3300kv will only take a 3s max. Bummer? Man, I wonder what it would do hooked up to RC4WD's 2 speed!? I'll bet that would be insane! If I can't power up, I can gear up! Last edited by Hwheeler73; 05-09-2014 at 08:07 PM. |
05-09-2014, 08:24 PM | #26 | |
I run all of it on 4s! Once the 90 day warranty is up, it costs the same to have it fixed... Then again, this was my last rotor.. The top and bottom, clean looking, magnets, are separating from the armature.. New one showed up yesterday. | |
05-09-2014, 08:34 PM | #27 |
| Re: The "Official" Fastest Wraiths on RCC thread. |
05-09-2014, 08:42 PM | #28 |
It's cheap fun and well worth it! I can't wait to dump a 5 or 6s in it!
05-09-2014, 11:14 PM | #29 |
well i changed the pinion gear to a 13 from an 11 and got the Time Bandit up to 18mph....on 2 2s 20-30c lipos, gonna try a single 4s 60c lipo and see how that does...
05-12-2014, 01:35 PM | #30 |
RCC Addict Join Date: Oct 2012 Location: Charleston South Carolina
Motor: Hyperion 6.5T sensored ESC: MMP Gearing: 13/54 32 pitch Battery: Flight-Max (I think) 3300mah 50C 3S Misc: Stock front gears (I'm waiting for those to fail) and heavy duty stock ratio gears in the rear. MIPs, RRP transmission gears, VP Dig, Hot Racing Spools, worn out Axial Unis. R35 Axial Ripsaws and Duuuuuude 2.2 wheels with LURC rings. Not half bad! Last edited by Lentsnh2012; 05-12-2014 at 01:47 PM. |
05-12-2014, 03:39 PM | #31 |
Pebble Pounder Join Date: Feb 2012 Location: Aurora
05-25-2014, 09:09 PM | #32 |
Second post updated with everyone's speeds. I know there has to be more people that are willing to strap their phone in their crawler and go fast. Evan? Winnerone23?
05-26-2014, 05:46 AM | #33 |
I finally got mine back together. Yay!!!! Blew 2 rid ends and a housing apart already.. it was SO worth watching it happen tho! Updates in my build thread soon. |
05-26-2014, 01:37 PM | #34 |
Hmmmm I made a deal with myself to not run more then 4s anymore. Looking into the speed app. Okay ap is installed will see what 3s does first. Guesn 15 or so 150 trackstar esc, turnigy 2100kv 1/8 scale. 56/14 32p cant remember what gears are in the axles. axle gears are a routine failure no matter what i put in so ive since forgotten. tires are rb2 battery is rhino 3s 2200 40c discharge 4s. runs are on my loose gravel driveway and slid sideways and tumbled through the sheet grass. al luck would have it i cant find my cable to make a 5s out of 2 and 3s so my speed run testing is done ;) for now. with paddles on the rear and in the sand she handles like a formula one care so maybe speed runs will happen later on. paddles are 6" wich also increases ground speed. topping off a 4s. also thinking about trying 5sbut itgets uncontrolable and my phones straped to outside of the cage because it doesnt fit inside. also had some steering issues for first runs. can now kinda guess at the 5s and 6s speeds. 3s on 2100k can climb most things. cut pitts freaking rock on the rocks and in the dirt. i so wish more people would hack on there tires slow motion on 3s with the tsl probly 10mph with the smaller rubber still climbs most things Last edited by evan03; 05-30-2014 at 05:55 AM. |
05-26-2014, 03:47 PM | #35 |
Rock Crawler Join Date: Feb 2011 Location: Spur, TX
Hmm.. Might try a different program than My Tracks, not sure how accurate it is. Could just be my misguided perception as well, seems alot quicker than this. 13.23 mph as a top speed. Pro4 3300kv with an AX2 two speed trans in high gear, 15/54 32p gearing on 3s with 2.2 ripsaw tires. |
05-26-2014, 04:00 PM | #36 |
That sounds pretty slow with that gearing and a 2 speed.. But from my experience, My tracks, is pretty spot on. I tested it against other apps, speedometer's, and my pedal bikes tach.. For years I rode bike and stopped using a tach when I realized My Tracks was good.. I'll be testing tomm maybe. Have to replace parts.. Shot it up this tree from the right side of my son (his left arm). I was dam near nosed up to the limb on the left. About 12' up.. Blipped the throttle and came down on all 4's.. Straight down! And so it goes.. It landed hard and didn't rebound. I only had front wheel drive as well.. NEXT!!! |
05-26-2014, 07:13 PM | #37 |
Crunchy rides again! Jeeze dude, I'd hate to have your repair bills. But it's all good. I killed two front ring and pinions on Saturday alone. Time for some aluminum housings to hold this together.. looks like for you as well. |
05-26-2014, 07:41 PM | #38 |
It's a cheep fix.. I have the stock housings I took off for the Dlux housings with 16mm bearings. I can see why backing off to a 13mm bearing was a good move. Then again, I don't think they are naturally meant to drop 12' out of the sky and take the Sudden stop at the bottom! ???? Edit.. Yes.. I think it might be time for some aluminum housings tho.. Just not the Currie's.. Do they still make the aluminum housings that aren't Currie's? Last edited by winnerone23; 05-26-2014 at 07:44 PM. |
05-30-2014, 12:28 AM | #39 |
Quarry Creeper Join Date: Apr 2014 Location: USA
Ran mine last night with the Cellphone strapped to it. Hobbywing 3400KV motor with MMP ESC and a 2S. Geared with 32 p I think 15 or 16 pinion with 56 Spur = 13.6 MPH. I figured it was slow watching it but I'm used to my Stampede which is pretty quick. I think I'm going to need to build another one more Formula Offroad style . 3S is in the mail as I type though so I will be curious to see how it boosts the speed. Certainly won't be the "fastest" by any stretch .
05-30-2014, 05:46 AM | #40 |
I bet it boosts it 5mph. 18 is pretty fast |
The "Official" Fastest Wraiths on RCC thread. - Similar Threads | ||||
RCC Official "RC-Recycler" is out of his damn mind thread | STANG KILLA SS | Chit Chat | 92 | 12-09-2015 04:21 PM |
Nebraska Scale Crawlers Association "official business" organization thread... | JavelinSST390 | Nebraska | 17 | 01-27-2009 08:14 PM |
