09-01-2014, 08:44 PM | #61 |
Rock Crawler Join Date: Jan 2012 Location: middle TN
| Re: The "Official" Fastest Wraiths on RCC thread. Sure haven't. I haven't even touched it since that speed run. I need to fix where both back wheels slipped the beads first. Work has been kicking my a$$ lately to the point that when I have a day off I try to relax and spend time with the family. I will try that speed run again though. |
09-01-2014, 08:45 PM | #62 |
Ok, so after I replaced the front axle housing, I took her out for a run... Finally remembered to drop the GPS in her.. Hh Trailmaster BL 3100kv on 4s.. Can't wait to get the Pro4 4000kv back in for a test run! |
09-03-2014, 11:34 AM | #63 | |
Quarry Creeper Join Date: May 2012 Location: Baja, Mex / Calexico, Ca.
| Re: The "Official" Fastest Wraiths on RCC thread. Quote:
my setup is a hobbywing 3656sd 3400kv 4-pole lipo 3s 6500mah 65c esc hobbywing 120a gearing 54/13 but I dont a servor righ now so, I will wait for my new servo and try some speedruns to post the results here. | |
09-07-2014, 09:10 AM | #64 |
Rock Stacker Join Date: Aug 2014 Location: NorCal
Damn! Some nice @$$ set-ups, fellas! I've got my Wraith on a Tekin Roc412 3100kv married to a Mamba Max Pro. I've only been running 2S. I'll pick up a 3S and see what I clock it at. |
10-08-2014, 07:31 PM | #65 |
Pebble Pounder Join Date: Jul 2013 Location: Candler
Definitely not as fast as others but at least I'm on the board now. Traxxas vxl ESC and motor. Not sure on pinion but spur is 80. Factory ratios front and rear. On 3s 5000. Pretty happy with this, will try again on a fresh battery. That pack had close to an hour of run time before I thought to check it so I could post here. Edit.... Downloaded the app that everyone else has used. Results were the same as my gps. Removed the front drive shaft to see if that would add any speed. It wouldn't, it spun all the way to 20 mph. Was a pain to drive, stayed sideways most of the time. Last edited by DTB1; 10-11-2014 at 05:44 PM. Reason: added more info and picture. |
01-16-2015, 08:54 AM | #66 |
Bump it up! Voltage, gearing, and motor! Pro4 HD 3500kv, 54/13 gearing, on 4s... |
01-27-2015, 06:09 PM | #67 |
Quarry Creeper Join Date: Dec 2005 Location: the first state
Mine is set up for trails and rocks. Its geared down and i run brushed. I put the 20t stock motor in and tossed in a 3s. Best run i got 12mph, but the phone fell out after that while i was trying to go faster and i closed the app before i got to take a screen shot. But that should give you guys an idea of a stock brushed motors speed. If i get time tomorrow i may put it all the way back to stock if i can find the stock gears and do a couple runs. |
02-10-2015, 12:41 PM | #68 |
Pebble Pounder Join Date: Jul 2014 Location: Atlanta
I've got a wroncho. Does that count? I'm getting mine put back together with some new parts. I'm running a mmp and a 3300kv pro4 geared at 14/56 on 3s. I'll get the app and see what it can do. I'll post in a couple weeks when I get it ready
02-17-2015, 02:11 PM | #69 |
Quarry Creeper Join Date: Feb 2006 Location: Muskegon
Just subbing, my Wraith got here today! I'm still at work lol |
02-17-2015, 07:02 PM | #70 |
Quarry Creeper Join Date: Jun 2013 Location: South jersey
Why have i never seen this thread before?! because god didn't want me to break my rig! now that I found it, it may be time to turn the rx8 current limiter up to 100% and have my way with the old girl when i finish the overhaul...
02-17-2015, 07:57 PM | #71 | |||
02-17-2015, 08:00 PM | #72 |
| Re: The "Official" Fastest Wraiths on RCC thread. |
02-19-2015, 03:05 PM | #73 |
Timbuk2, 18 turn, 2s 20c 5000mah It may be time for the Sidewinder. |
03-27-2015, 01:37 PM | #74 |
Update, Hh Crawlmaster 13t,3s 5500 mah 30c pack, AE-5 |
03-28-2015, 05:23 AM | #75 |
Pebble Pounder Join Date: Mar 2015 Location: Fairland
I have a Hobbyking x-car 120a ESC with a Trackstar 4 Pole 4850KV motor in mine and the thing screams....and I can still creep ever so slowly. As soon as I get my RR Steel Idler gear I will do a speed test and post MPH on here along with a short video.
03-31-2015, 11:48 PM | #76 |
Rock Stacker Join Date: Dec 2014 Location: Tasmania
Finally got around to checking how mine does. Trackstar 10.5t, X-car 120a, 2200mah 3s geared 12/60. Perfect for what I do with it, crawls very smooth and gobs and gobs of torque. |
04-01-2015, 05:28 AM | #77 |
my pro4 went bad 2 runs after this and I still haven't fixed it lol I ordered a rotor yesterday.
04-02-2015, 09:20 PM | #78 |
Pebble Pounder Join Date: May 2010 Location: Brew City
Max speed: 17 mph Motor: Teking ROC412 ESC: CC MMP Gearing: 56/12 Battery: LiPo 3s Total Rig Weight: 9 lbs. Comment: Fast enough!! |
The "Official" Fastest Wraiths on RCC thread. - Similar Threads | ||||
RCC Official "RC-Recycler" is out of his damn mind thread | STANG KILLA SS | Chit Chat | 92 | 12-09-2015 04:21 PM |
Nebraska Scale Crawlers Association "official business" organization thread... | JavelinSST390 | Nebraska | 17 | 01-27-2009 08:14 PM |
