05-09-2014, 04:25 PM | #1 |
Rock Crawler Join Date: Dec 2007 Location: MERICA!
| Ring and Pinion
I want to put the heavy duty ring and pinion gears in my rig, if I go from stock 38/13t to 43/13t will that give me more wheel speed? What would guys recommend me doing? I'm running a 4000kv motor. Thanks |
05-09-2014, 04:28 PM | #2 |
| Re: Ring and Pinion
Know how to divide? Divide 38/13 and divide 43/13 and which number is closer to 1? Or pretend your trying to figure out a spur gear and pinion gear relationship. With division. |
05-09-2014, 04:28 PM | #3 |
RCC Addict Join Date: Jul 2013 Location: Planet Earth
| Re: Ring and Pinion
The 43/13 is an under drive gear...No..will slow down the wheels on the axle you put them on. 36/14 are the overdrive gears that would increase wheel speed. 38/13 is stock if its geared the same as an scx10 If you're looking to CRAWL only use the OD in the front and the UD in the rear. If you trail with your wraith chose either the OD for the front or the UD for the rear but not both. Or you can simply buy HD axial stock gear ratios. Last edited by 6sharky9; 05-09-2014 at 04:37 PM. |
05-09-2014, 04:41 PM | #4 |
Rock Stacker Join Date: Jun 2013 Location: watertown
| Re: Ring and Pinion
I would recomend running the 43/13 in the rear with the 36/14 in the front will give you a tighter turning radius and will help in some tight crawl spots. I run the 4000kv pro 4 on 3s with a 5/1 ration on the trans with the OD gears up front and UD gears in the rear not the best for going fast but it does help in crawling. Also if your upgrading your ring and pinion i would recomend new lockers front and rear the pro 4 is no joke and will destroy parts if your not light on the trigger.
05-09-2014, 04:49 PM | #5 |
| Re: Ring and Pinion
Depending on how many cells you plan on running you might want to stay away from the OD gears. No matter how tight I shim them I can't get them to last on 4s.
05-11-2014, 09:01 AM | #6 |
| Re: Ring and Pinion
Ya I think I'm gonna go with stock ratio heavy duty gears. Just blew up my tranny stock gears and put hot racing steel gears. Also bought hot racing steel lockers and mip drive shafts. Thanks for the info! |
Ring and Pinion - Similar Threads | ||||
Ring and Pinion #'s | rockslyder | Vaterra Twin Hammers | 2 | 10-21-2013 05:09 PM |
Helical ring and pinion gears sets with an offset pinion? | Calderwood | General Crawlers | 6 | 09-14-2013 09:06 PM |
ring and pinion | luv2ridemx | Axial Wraith | 4 | 12-16-2011 11:02 AM |
Ring and Pinion | Garry | Venom Creeper | 6 | 10-11-2010 04:30 PM |
36/14 ring and pinion? | JaredVW | Axial AX-10 Scorpion | 10 | 11-09-2009 08:00 PM |
