05-12-2014, 10:11 AM | #1 |
Newbie Join Date: May 2014 Location: israel
| Motor for Wraith with RC4WD AX2 TRANY
Looking for a good motor and ESC for my wraith i have RC4WD AX2 Trany and i want a good speed i have looked at the SKYRC Toro TS120 With Tekin RedLine 13.4t Motor Did Some one tried the SKYRC ESC and the combination ? |
05-12-2014, 10:35 AM | #2 |
Newbie Join Date: Sep 2011 Location: Gilbert
| Re: Motor for Wraith with RC4WD AX2 TRANY
I run the Tekin ROC412 3100kv with an AX2, I love it.
05-12-2014, 11:57 AM | #3 |
Rock Crawler Join Date: May 2012 Location: Minneapolis
I've run a Tekin 13.5 in one and it's a great combination at an affordable price. The esc you mention is unknown to me, I ran mine with a castle MMP. Whatever you do, brushless is a necessity as the high gear will eat up brushes in a brushed motor if the rig has any load on it. Dna |
05-12-2014, 12:16 PM | #4 |
Pebble Pounder Join Date: Feb 2004 Location: Born in a crossfire hurricane
I run a cheap Traxxas 21t motor on mine with no problem. You have to gear for high gear performance, which means much lower than the standard spur and pinion gearing of 4:1 . I'm using a 60/12 gear and I'm pretty pleased with it. I've use 60/9 and that's a bit low for high gear. You just have to accept low gear as it is. For me this works great. I have good high gears speed, motor doesn't get too warm, and it crawls like mad. Obviously you'll get more speed from a brushless, but the whole point of a 2 speed transmission is to be able to select gearing. Some guys don't feel the 2 speed is necessary, to each their own.
05-12-2014, 05:57 PM | #5 |
Rock Crawler Join Date: Feb 2011 Location: Spur, TX
Running a Pro4 3300kv, MMP and the AX2 with 15/54 gearing. Does good crawling, and has more than enough power for bashing around in high gear.
05-12-2014, 06:02 PM | #6 |
Who's 54t spur are you using? Did you swap out the whole slipper assembly? Sent from my SCH-I545 using Tapatalk |
05-12-2014, 06:10 PM | #7 |
| Re: Motor for Wraith with RC4WD AX2 TRANY |
05-12-2014, 06:12 PM | #8 |
I would like to upgrade my slipper assembly. Robinson's would be nice. Sent from my SCH-I545 using Tapatalk |
05-24-2014, 02:54 PM | #9 |
Newbie Join Date: Mar 2013 Location: Manassas
Will the stock motor last long with this and RR slipper setup? Ordered the ax2 today and running an old v1 sidewinder esc. Want some speed when its needed but this is primarily a trail/crawler rig. Sent from my GT-P5113 using Tapatalk |
05-25-2014, 12:03 PM | #10 |
I can tell you that with the more powerful motors you'll want to upgrade the output shaft to the heavy duty version on the AX2. I suspect the stock wraith motor will do great in low gear, however high gear is liable to kill it quickly due to heat.
06-09-2014, 02:15 PM | #11 |
Pebble Pounder Join Date: Feb 2012 Location: Aurora
Is first gear on the AX2 taller than the standard wraith tranny?
06-09-2014, 02:18 PM | #12 |
Quarry Creeper Join Date: Oct 2011 Location: New Mexico
06-09-2014, 02:46 PM | #13 |
High is 1.78:1 and Low is 5.05:1 The stock tranny is like 3:1 Sent from my SCH-I545 using Tapatalk |
06-09-2014, 03:02 PM | #14 |
Motor for Wraith with RC4WD AX2 TRANY - Similar Threads | ||||
rc4wd ax2 VS R3 2speed transmissions | sec1083 | General Crawlers | 4 | 12-31-2013 10:42 AM |
Rc4wd ax2 trans | Tmaxxed | Axial SCX-10 | 2 | 08-10-2013 09:44 PM |
Help with motor choice on RC4WD AX2 2 Speed. Gear ratios provided | it8ezbngrn | Axial Wraith | 2 | 04-12-2013 10:13 AM |
