05-14-2014, 11:37 PM | #1 |
Rock Crawler Join Date: Jun 2013 Location: Knox, IN
| Super Shafty Ultimate Motor Plate
What size machine screw is the Super Shafty Ultimate Motor plate tapped for where the gear cover bolts to the Ultimate Motor Plate. The stock plate is plastic and the screws are Self Tapping. I do NOT want to strip out the tap in the holes. Thanks! |
05-15-2014, 11:04 PM | #2 |
Quarry Creeper Join Date: Feb 2011 Location: Princeton Illinois
| Re: Super Shafty Ultimate Motor Plate
i used the stock screws on both of my SS motor plates with no problems
05-16-2014, 05:37 AM | #3 |
Newbie Join Date: Nov 2013 Location: Lakeside
Same here.
05-16-2014, 10:46 AM | #4 |
| Re: Super Shafty Ultimate Motor Plate It is not tapped, it is drilled slightly under-sized so that the stock cover screws should tap themselves on initial install...just be careful and take your time installing them.
05-16-2014, 11:04 AM | #5 |
Rock Crawler Join Date: May 2012 Location: Minneapolis
The original batch was tapped with an m3 screw size. Required you to drill out the plastic holes in the cover. The later batches are just like natedog says. I used my 3mm tap to make them all the same. Dna |
05-16-2014, 02:24 PM | #6 |
Thanks Guys!
Super Shafty Ultimate Motor Plate - Similar Threads | ||||
ULTIMATE motor plate question | jenijohnk | Axial Wraith | 8 | 07-29-2013 10:50 AM |
*Ultimate Formula Offroad Giveaway* BWD Whiplash Full Kit with Motor Plate! | billet works | Formula Offroad | 341 | 08-07-2011 10:49 PM |
