05-17-2014, 03:39 PM | #1 |
Newbie Join Date: May 2014 Location: Johnson city
| What's a good ESC and good servo for my wraith without having to have BEC?
I have a axial wraith and I need to upgrade my servo and everywhere I read tells me I need a BEC? I need a aftermarket ESC also perferbly waterproof on both? Any suggestions?
05-17-2014, 05:46 PM | #2 |
Quarry Creeper Join Date: Mar 2014 Location: Athens, Al
| Re: What's a good ESC and good servo for my wraith without having to have BEC?
I would suggest a Castle Creations Mamba Max Pro. its a great unit. To my knowledge, and someone correct me if Im wrong, but you don't HAVE to run a BEC its just more of a guideline and i a good choice to help with powering you're high torque servos. i didn't run one on m mine for ever and i run savox 1230sg servos front and rear which are 499.9oz/in. so extra strong there and i def would recommend them. As far as waterproofing i wouldn't trust buying something that is already "waterproof". My roommate went that route on more than one occasion with more than one company and they worked ok at first but all eventually freaked out. Just get you some liquid electrical tape and shake out one of the guides on this site for waterproofing electronics. |
05-17-2014, 07:40 PM | #3 |
Rock Crawler Join Date: Oct 2013 Location: Wiscasset, ME
I support Solar servos. Run them in all my trucks. $20 for 400oz. Can't beat it. As far as waterproofing, I'm going to have to recommend conformal coating over liquid electrical tape. Its not as easily accessible but its SO much better! I've done both methods. The MMP is a good call. Conformal coating can be found on Amazon pretty cheap and one bottle will last a long time. |
05-17-2014, 10:06 PM | #4 |
im not to familiar with this stuff? What is it exactly?
05-17-2014, 10:24 PM | #5 |
Just deal with connecting a bec and get it over with, consider it an electronics insurance policy. While I don't recommend it, yes an mmp CAN work ok without a bec on 2s... doesn't mean you SHOULD. |
05-17-2014, 10:46 PM | #6 |
Quarry Creeper Join Date: Aug 2012 Location: Anchorage
Love my waterproof br-xl from Holmes hobbies, it's made by castle. Your local hobby shop will prolly do the soldering for cheap. If that's what your worried about. |
05-18-2014, 09:05 AM | #7 |
Been running my track star 150 without a external bec for 2 years. Currently running a savox 1268. And a 1/8 2200kv motor on 2-6s. No problems at all and seems to run well against high dollar tekin motors and 400 oz servos. Not quite as smooth but I'll take that since i saved a few hundred dollars on the power combo but also have gobs more power. 150 sensored track star http://hobbyking.com/hobbyking/store...grammable.html Probly take 3 weeks to get is shipped. Keep in mind this compared to esc's with twice the price tag. This is rx8 territory This is a fantastic servo for the money I run them on big planes and tried it on the wraith does damn well and never failed. http://hobbyking.com/hobbyking/store...dProduct=23597 While I'm on the bargain bin parts. I rarely spend as much money in the hobby as the rest do but find products that are long lasting priced well below popular brands but still compare. Cheap servo arm. http://hobbyking.com/hobbyking/store...dProduct=23598 This is 25 spline or futaba. HK also stocks hitech spline Hitech http://hobbyking.com/hobbyking/store...dProduct=23602 Last edited by evan03; 05-18-2014 at 09:32 AM. |
05-18-2014, 03:36 PM | #8 | |
| Re: What's a good ESC and good servo for my wraith without having to have BEC? Quote:
05-19-2014, 05:44 AM | #9 |
I've got tons of videos. I think it does very well crawling . I'll see what I can dig up. Not finding much for rock crawling I was in fast bashing stage back then. This is also the 150 track star and 2200kv 1/8 scale motor with no sensor ESC is putting 5.7volts to servo. Last edited by evan03; 05-19-2014 at 06:13 AM. |
05-19-2014, 02:41 PM | #10 |
well heck I'm sold enough now to at least try one out lol.
05-19-2014, 09:40 PM | #11 |
Awesome. Make sure you get the metal arm to. My savox is getting sloppy so I'll swap on the hxt 10kg. Ohhhh the hxt 10kg runs very smooth when greased and is very easy to do. But if you don't grease it it will still work great |
05-20-2014, 03:48 PM | #12 |
Rock Stacker Join Date: Jun 2013 Location: watertown
Strongly recommend running a bec it eliminates any glitching or issues you may have with out one and it will let you upgrade to a stronger servo down the road with no hassle. the conformal coating is a reat way to water proof its thin so still lets heat escape but provides a barrier between the board and water I use it with all the board i do at work works fantastic very easy to apply.
05-20-2014, 06:06 PM | #13 |
A bec does not eliminate any and all gliching. Yes it does work. Yes it is the holy grail of the Rc world. Do most run them yes. Do we all need to run one , no. The bec seems to be a fix all almost as good as snake oil rubbed on the tires for better grip Last edited by evan03; 05-20-2014 at 06:10 PM. |
05-22-2014, 08:44 PM | #14 |
Rock Crawler Join Date: Apr 2004 Location: Not where I belong.
Your're better off making your decision based on what a B.E.C. actually does rather than a craptastic comparison to snake oil. An esc supplies power to a motor but also to the receiver, and subsequently whatever you have plugged into the receiver. The first common problem with the setup is when you want to supply more voltage to the system than the esc is designed for. For example having a servo that's rated for 400oz at 7.2v may only be 300oz at the 5v your esc supplies. The second common problem is when the esc can't supply enough amperage. One servo may not pull enough amps to notice but throw in a second servo, winch, light bar, etc the esc may not be able to supply the needed amperage and may become unresponsive or die all together. The purpose of a Battery Eliminator Circuit is to allow you to set the amount of volts while supplying more amps to the radio side of your setup. There are a few different ways to wire the B.E.C. based on what you are wanting it to do. You also said you "need" an aftermarket esc without saying which esc you currently have. Going out on a limb and guessing that you have an AE-2. Most of the time a B.E.C. is reccomended to run with an AE-2 is becasue the B.E.C. in the AE-2 is only rated for 2cell lipo and usually dies when you try and run 3cell As far as waterproofing, take some time to read this thread. Water Proofing Electronics |
05-23-2014, 08:09 PM | #15 |
When do most receivers brown out ?
05-24-2014, 10:09 AM | #16 |
| Re: What's a good ESC and good servo for my wraith without having to have BEC? More specifically it's the esc browning out when it can't supply enough power to the receiver and what's plugged into the receiver. For example if your front tires are in a bind and you try to turn. The closer you get to stalling the servo the more power it wants. If the esc can't supply enough power it may become unresponsive or die all together. On the flipside, if the esc can supply power without browning out and you don't feel the need to send more voltage to things, you don't necessarily need a B.E.C. I'm not trying to cram my opinion down anybody's throat whether they should run a B.E.C. or not, it just gets annoying when the topic is debated without an understanding of what you are trying to accomplish with B.E.C. |
05-24-2014, 10:41 AM | #17 |
Pebble Pounder Join Date: Dec 2013 Location: Burbank
I agree with spooky, and would add that for $20 just add a castle bec and be done with it. |
05-24-2014, 07:42 PM | #18 |
True.
05-24-2014, 09:06 PM | #19 | |
RCC Addict Join Date: Jul 2013 Location: Planet Earth
The stock Axial ESC can Handle just under 200oz without a BEC but not with lights and a winch added to it all...The stock esc only provides 5v. I would venture to say at 6v you can handle something with 200 or just over without needing a BEC...Again; without lights and a winch unless they have a separate power source. If you feel you need a 300 400 500 600oz servo you definitely will need a BEC if you run lights and a winch or not if you want the power you paid for. Consider some upgrades to the steering system as well. I run a 177 oz/tq servo in a scx10 without an external BEC and have had zero problems with it so far....Then again I only use 1.9 tires so don't need as much power you would need to turn 2.2 tires effectively. The powerful low cost servos aren't waterproof to my knowledge so not sure you want that anyway..Check savox for a wp servo with just over 200oz of tq...you shouldn't need a BEC to use it and have plenty of turning power..you're not going to move the earth with it but it should work just fine. | |
What's a good ESC and good servo for my wraith without having to have BEC? - Similar Threads | ||||
What's a good esc and servo for under $81? | Tim_B | Newbie General | 14 | 03-28-2008 04:45 PM |
Good small ESC with no reverse delay or high amp BEC ??? | roktoy | Electronics | 19 | 11-14-2006 11:26 PM |
