05-23-2014, 05:45 AM | #1 |
Rock Stacker Join Date: Apr 2014 Location: canada
| more steering angle on wraith?
looking to get more steering throw out of my wraith ....what do I need to upgrade...maybe cvd in front or??????
05-23-2014, 06:08 AM | #2 |
Rock Crawler Join Date: Jul 2009 Location: Victoria Australia
| Re: more steering angle on wraith?
Do you have the RTR or kit version, kit comes with uni's that are better and can be modded for more steering, search on here as it's been covered before.
05-23-2014, 12:27 PM | #3 |
Quarry Creeper Join Date: Feb 2011 Location: Litchfield park
I gained quite a few degrees of steering by just going from the dog bones in the rtr to the Universals. That is a 100% must for more angle if you don't already have them. If you do however I'd look into the knuckles and chubs as those are probably rubbing.
05-23-2014, 01:38 PM | #4 |
Newbie Join Date: Oct 2011 Location: Calgary
CVD in the front is a must on a RTR. A longer clamp-on style servo horn does help. Also get either the VP ackerman steering arms or something like crawlingcalvin's arms out of the vendors section. They will give you more angle. |
05-23-2014, 01:44 PM | #5 |
Newbie Join Date: Dec 2013 Location: CFL
05-23-2014, 01:52 PM | #6 |
| Re: more steering angle on wraith? I strongly disagree. Universals are capable of much more steering angle than cvds. They also don't have to sacrifice material around the pin to gain steering travel so they are typically stronger as well.
05-23-2014, 02:06 PM | #7 |
I meant Universals. Try googling Axial CVD like I just did. It comes up as the same thing. For our "rigs" atleast. Obvioualy they are NOT the same for 1:1rigs
05-23-2014, 02:34 PM | #8 | |
| Re: more steering angle on wraith? Quote:
Universal, not CVD. You want NON ACKERMAN in a crawler as this will give you the most steering. Ackerman arms are good if it's a high speed machine and you want straight line stability. | |
05-23-2014, 08:01 PM | #9 |
The dude will hate me but I always push the dinky steering set up. I would not recommend a longer servo arm on a rtr servo. I've been running stock universals and the provide more steering then I have servo power. The last thing I'd do is install a longer servo arm. Let's leave that to the hitech fan boys ;) |
05-23-2014, 08:19 PM | #10 |
Installing a longer servo arm is the equivalent of gearing up, but for a servo. If it can handle it and the mechanical setup is capable then sure why not. I agree the universals are mostly capable. At full lock and on power is a rough situation for any steering setup. Can't comment on the dinky mount so much, its a comp crawler part. |
05-24-2014, 06:18 AM | #11 |
The arm on the dinky set up is swinging towards the center this creates more throw. On the stock steering it would s swinging away. I kinda like the looks compared to the stock steering. I can run a one hole closer on the servo arm and have about the same steering as the stock set up on the furthest outer hole on my servo arm Last edited by evan03; 05-24-2014 at 06:24 AM. |
05-26-2014, 09:36 AM | #12 |
so if I grab the rc4wd extreme duty front cvd set will that help?
05-26-2014, 10:39 AM | #13 | |
I wanna be Dave Join Date: Feb 2007 Location: BFE, NV
Axial Wraith Universal Set | |
05-26-2014, 11:17 AM | #14 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
Another vote for 4WS. That is the only way to make a wraith turn tight. It's cheap enough to do.
05-26-2014, 08:13 PM | #15 |
ya I read them..... They just are not very strong looking imo.the vanquish vvd or rc4wd ones look stronger to me.
05-26-2014, 08:21 PM | #16 |
RCC Addict Join Date: Oct 2012 Location: Charleston South Carolina
| Re: more steering angle on wraith? |
05-26-2014, 09:21 PM | #17 |
Quarry Creeper Join Date: Apr 2006 Location: sweethome
I have a lot of steering with axial universals and I clocked my c hubs back .
05-27-2014, 02:15 PM | #18 |
ok maybe I will give em a go and see if they last.
05-27-2014, 02:32 PM | #19 |
05-27-2014, 02:44 PM | #20 |
I've popped a couple universals at the joint, but feel comfortable calling it idiot driving when I did it. They are worth their price. Anything at full lock can be weak...
more steering angle on wraith? - Similar Threads | ||||
RC4WD XVD Axle for Axial Wraith with 50° steering angle | RPP Hobby | RPP Hobby | 5 | 01-16-2012 09:45 PM |
Steering angle | BOB8789 | Axial SCX-10 | 6 | 01-13-2012 10:55 PM |
Steering Angle | HiloDB1 | Kyosho Crawlers | 1 | 11-26-2008 11:05 AM |
Steering angle | NeoSlayer888 | Tamiya TLT Crawlers | 3 | 10-29-2005 07:21 PM |
