06-01-2014, 12:38 PM | #1 |
Quarry Creeper Join Date: Apr 2014 Location: USA
| MIP install question Kit 11116 (driveshafts)
Hey guys, I don't even have the body on my Wraith kit yet and I busted a read driveshaft bouncing in some rocks . I see the MIP replacement is Kit 11116. I know for my Stampede the only had grub screws to clamp in onto the outputs. Looks like this kit also has grub screws. Is there any extra part number to get pins that go through the tranny output and not just clamp down on it or does it come with those and I'm just not seeing it correctly? or can the stock Axial threaded pins be used? |
06-01-2014, 12:52 PM | #2 |
| Re: MIP install question Kit 11116 (driveshafts) The grub screws you see in the pic are for holding the cross pins in the cvd joint. The screw shafts are for attaching the hubs onto the trans outs/axle ins. Yes you can keep using the stock screw shafts if you want, as these mip hubs are threaded m3. Which is a downgrade IMO and only god knows why they went that direction... |
06-01-2014, 12:53 PM | #3 |
I wanna be Dave Join Date: Jan 2012 Location: CANADA
Stock Axial pins can be used for sure with that kit. The kit should also now come with them.
06-01-2014, 12:56 PM | #4 | |
You beat me by 10 seconds...lol. Yeah it sucks MIP use the M3 screw pins for this Wraith kit. I am disappointed in that part but bought some spare pins in case I break one. They are cheap in packs of 10. I think some guys have tapped them to use M4 Traxxas pins? http://www.amain.com/product_info.ph...3mm-Screw-Pins Quote:
06-01-2014, 01:07 PM | #5 |
The old ax10/scx10 mips came m4 for years. Its not that they snap, its that using a 1.5mm driver to tighten something like this plain sucks. Had to use the longer wraith hub in one setup I have and cringe every time it needs to be removed... |
06-01-2014, 01:09 PM | #6 |
Oh okay I guess I have been lucky with my pins and removal.
06-01-2014, 02:42 PM | #7 |
Thanks guys, ordered. So what breaks next? I already have a Super shaft top shaft, metal tranny gears, 32P pinion and RR slipper. I'm also running Motorworx wheels. So I guess it's be the ring and pinion if anything? One other not so related issue. Seems that my hex's keep loosening up and I already lost one of the pins (that is slides over on the axel output). I used blue Locktite but it's happened a few times. Is this usual? Any upgrades here? Oh, and the Axial Hex has a flange on it making it not go as deep into the recess. I was fitting some Sandpaws on Desperatos for fun and the hex didn't even seat deep enough to grab. |
06-01-2014, 03:13 PM | #8 |
VP makes clamping style hexes. I have never used them but they could be good. http://www.vanquishproducts.com/12clhexhu.html I know what you mean about the flange, kind of sucks for custom wheels like Mayhem's. I have not had my hexes come loose with blue loctite. Yeah your stock ring and pinion should be upgraded to the Axial Heavy Duty. Edited version.......Mayhem rims fit perfectly on Axial hexes, I was thinking of my RC4WD hex conversion kit for the Tamiya Bruiser. They are flat hexes and the Mayhem rims actually have the nice flange hole/divet on the back of the hubs. Last edited by ZippoMan; 06-01-2014 at 07:18 PM. |
06-01-2014, 09:58 PM | #9 |
Quarry Creeper Join Date: Apr 2006 Location: sweethome
I have been running the ax 10 ones they use the bigger traxxas pins .had to trim the gear cover .And there cheaper.
06-01-2014, 10:19 PM | #10 |
Newbie Join Date: Nov 2013 Location: Lakeside
| Re: MIP install question Kit 11116 (driveshafts) |
06-02-2014, 08:38 AM | #11 | |
Quarry Creeper Join Date: Mar 2008 Location: Redlands
| Re: MIP install question Kit 11116 (driveshafts) Quote:
06-06-2014, 10:53 AM | #12 |
Rock Stacker Join Date: Jun 2014 Location: Europe
Hello all, Question MIP cardan: MIP 11116 center CVD wraith cardan be good or bad ? I think order soon. Added: therefore to ask, when my scx10 Mip 10145 cardan hit Spur gear ! ( maybe help drive hub long ). i order wraith Mip cardan, because i do not know better cardan. Last edited by axsand; 06-07-2014 at 12:40 PM. Reason: more info and matter |
MIP install question Kit 11116 (driveshafts) - Similar Threads | ||||
Question on MIP driveshafts | philsacbm13 | Axial Wraith | 9 | 02-01-2014 07:23 PM |
wraith kit with chaotic links - link install question | bikeboy | Axial Wraith | 4 | 06-30-2013 09:17 PM |
Getting ready to install my MIP :) | mr_manny | Axial AX-10 Scorpion | 3 | 08-24-2008 02:18 PM |
MIP TLT CVD Install - Q's RE: tips/tricks? | gr33nlite | Newbie General | 17 | 10-28-2007 12:46 PM |
