Thread: lockers
Old 06-02-2014, 02:58 PM   #1
Default lockers
What do you all think Hot Racing or VP lockers? Also why would you replace the pinion shaft bearings with bushings? thanks for the help
wyomingcrawler is offline   Reply With Quote
Old 06-02-2014, 03:19 PM   #2
Default Re: lockers
I personally have the VP lockers on my wraith and never had any issues with them. Vanquish Products is my weapon of choice.
MexicanMarauder is offline   Reply With Quote
Old 06-02-2014, 03:50 PM   #3
Default Re: lockers
The HR lockers are more solid than the stock iron cross but with as much slop (maybe a bit less.)
The VP lockers seem to be picky with axial universals (end engagement of axial uni's )
The bushing on the pinion is for those using big power & burning up bearings a lot.
Dostradamas is offline   Reply With Quote
Old 06-02-2014, 04:12 PM   #4
Default Re: lockers
do the locking set screws on the VP ones work with the stock rear axials?
Old 06-02-2014, 05:33 PM   #5
Default Re: lockers
Yes they will, but you may run into a problem with the Axial axle shaft's tang being too short for the set screws to properly do their job.
Locked UP RC and Hot Racing spools are also a great choice. You don't need bushings on the pinion unless you're running A LOT of power.
Lentsnh2012 is offline   Reply With Quote
Old 06-02-2014, 07:22 PM   #6
Default Re: lockers
Can't go wrong with the lockeduprc spools. Im running them in two trucks with big brushless power.
littletoyboy is offline   Reply With Quote
Old 06-02-2014, 09:54 PM   #7
Jus
Default Re: lockers
I'm a fan of the Hot Racing lockers. They are cheap and reliable.
Jus is offline   Reply With Quote
Old 06-03-2014, 12:58 AM   #8
Default Re: lockers
Another vote for the hot racing spools. They are nice.
J5races is offline   Reply With Quote
Old 06-03-2014, 01:09 AM   #9
Default Re: lockers
locked up spools here, way tighter tolerances than the hr spools resulting in much less slop
db450 is offline   Reply With Quote
Old 06-03-2014, 01:15 AM   #10
Default Re: lockers
Exactly what he said! Locked Up FI Spools all the way here.
SteveC6R is offline   Reply With Quote
Old 06-03-2014, 08:21 AM   #11
Default Re: lockers
Love my VP's, though I have VVDs front and rear as well.
rknaub is offline   Reply With Quote
Old 06-03-2014, 08:25 AM   #12
Default Re: lockers
Sweet thanks for the info........
Old 06-03-2014, 02:49 PM   #13
Default Re: lockers
I'm a fan of the hot racing spools. My rear lasted about a year running a combination of 3, 4 , 5 and 6 power. However a few months ago running 6" paddles in the sand she finally let go and stripped the inner out.
I've become to like locked up Rc stuff so I orderd a fi spool to replace the hot racing one. I also fitted a new inner shaft I really liked that they are advertised to be a press fit on the flange.
My fi spool isn't press fit and has a slight amount of slop. No biggie.
In my boom the first spool fit and finish seems to be just the same as hot racing.
I wouldn't run anything that requires set screws.
evan03 is offline   Reply With Quote
Old 06-03-2014, 03:01 PM   #14
Default Re: lockers
I busted 2 HR spools in the front of my wraith. Went with the VP locker and haven't had a problem since. But I do use them in my less powerful SCX.
hatefulboy is offline   Reply With Quote
Old 06-03-2014, 03:40 PM   #15
Default Re: lockers
That's weird I run a lot more power then most and I felt the hot racing spool spent a year being pretty dang awesome
Old 06-03-2014, 03:43 PM   #16
Default Re: lockers
I run a Pro 4 3300kv and just recently replaced my shot stockers with Locked Up FI spools. The shafts definitely took some force to get in place, so I have full confidence that they should last a while. Only had one run on them, though, because I'm currently missing the front half of my front MIP drive shaft. Not sure where it fell out, but it's gone!
Sh0rtBus is offline   Reply With Quote
Old 06-03-2014, 03:50 PM   #17
Default Re: lockers
I was hoping for the tight fit. Maybe I just got some looser ones. I'll be happy if I can run the first spools for a year like the hot racing
Old 06-03-2014, 04:01 PM   #18
I'm finally running the FI Spools in F/R.. HD gears and beef tubes F/R. The bronco wraith is holding up to anything I throw at it so far. The FI Spools are BA!
Sent from my SCH-I545 using Tapatalk
Markeje is offline   Reply With Quote
Old 06-03-2014, 04:51 PM   #19
Default Re: lockers
Was there a lot of wear on your axle shafts when you installed the fi spools? I had to remove material from the shaft on both of my trucks just to get them to engage. Definitely a press fit.
Old 06-03-2014, 05:26 PM   #20
Default Re: lockers
Brand new shafts
Axial universal. I was going to ppress fit them instead of removing material
lockers - Similar Threads
Replace Hr Lockers With Berg Lockers Yawzer General Crawlers 5 12-29-2008 10:51 PM
