06-03-2014, 12:25 AM | #1 |
Newbie Join Date: Oct 2012 Location: Olathe, KS
| Wraith slipper question.
First off I will say I have done a search and didn't find a clean cut answer to my question. I have made the switch to 32p on my wraith. Running a Tekin ROC 412 3100KV. I want to switch to a Robinson steel spur. I read in Harleys thread I believe, where he recommended switching to the $ lash steel slipper unit. My question is will the Robinson steel slipper unit and 32p gear be a bolt on replacement for my stock top shaft on my wraith? Thanks In advance guys! |
06-03-2014, 05:01 AM | #2 |
Rock Crawler Join Date: Feb 2011 Location: Spur, TX
| Re: Wraith slipper question.
Yes, it will work just fine. Just be sure to follow the installation instructions. Putting a bearing in the wrong place can cause issues with the steel slipper pad rubbing against the metal motor plate.
06-03-2014, 08:20 AM | #3 |
Pebble Pounder Join Date: Feb 2012 Location: Aurora
Ya there's a YouTube video or two that can help, worked great for me.
06-03-2014, 03:47 PM | #4 |
Im running the stock slipper with the nut cranked down as far as it will go. I upgrade what breaks and I've yet to upgrade the slipper in over a year of running. If it does fail I'll probly mechanically lock it with bolts through it or something. Don't really see much need for a slipper. Self control will save more parts then the slipper |
06-03-2014, 04:06 PM | #5 |
Quarry Creeper Join Date: Dec 2013 Location: Central IL
I've been running the RR slippers in both wraiths and have nothing but great results. I run them cranked down tight as can be. Sent from my SCH-I545 using Tapatalk |
Wraith slipper question. - Similar Threads | ||||
Slipper Clutch question | thisdougsforu | Axial SCX-10 | 3 | 02-23-2012 05:43 PM |
another slipper question | redrokin00XJ | Team Losi Comp Crawler | 5 | 02-27-2011 02:52 PM |
slipper question | spor706 | Team Losi Comp Crawler | 2 | 02-16-2010 08:22 PM |
wk trans slipper question | 4x4boy | HPI Wheely King | 1 | 11-02-2007 10:48 PM |
