06-15-2014, 02:32 AM | #1 |
Newbie Join Date: Jun 2014 Location: Portland
| Moving the battery behind the seats sideways.
Hi guys. I have been staring endlessly at my wraith, thinking about chopping up the chassis real good. I have an idea to cut down a bit of the interior, drill some new holes to move the seat forward, and place the battery sideways right behind the front seats. Has anyone seen this done successfully? I gather that moving the battery forward is the best bet for crawling, but I tend to do more bashing with this ride. I also would like to try something that is not as common. If I can make this work, my next project will be to cut about two inches from the rear of the chassis. |
06-15-2014, 01:11 PM | #2 |
I wanna be Dave Join Date: Jan 2012 Location: CANADA
| Re: Moving the battery behind the seats sideways.
I have not seen this myself but it sounds interesting. Post pics and I say go for it! It would be cool to see something different. It might be very tricky to get a battery in and out from that location. Where would you mount your ESC?
06-15-2014, 01:16 PM | #3 |
Ahhh check this thread out: Cams Wraith - Newest photos at the end. |
06-15-2014, 04:44 PM | #4 |
| Re: Moving the battery behind the seats sideways. |
06-15-2014, 08:21 PM | #5 |
That build thread is pretty much what I'm wanting to do. I'm curious why he moved it forward in the end, though. I've already built a nice water resistant tray in the front for wiring and electronics. Probably not my last placement, but it works good for now. I'm looking forward to seeing how your build comes out Evan. That is where I want to place my battery. Only 2S, though. I cannot afford the carnage a 3cell leaves me :-) |
06-15-2014, 08:56 PM | #6 | |
| Re: Moving the battery behind the seats sideways. Quote:
06-16-2014, 08:07 AM | #7 | |
06-16-2014, 10:13 AM | #8 |
Show us your Wraith!! How do you get up to 30mph? What motor do you run? I must be doing something wrong with my 2S set up. I have a MMP and Tekin Pro4 3300kv brushless and it tops out at just over 16mph. I have open diff front and axial HD stock ratio gears in the rear. HR aluminum transmission case with HR gears inside. MIP driveshafts............pretty much fully upgraded.
06-16-2014, 02:47 PM | #9 |
There's the pit! I'm running stock gears, a pro4 HD 3000, and a two speed tranny with 4-1 overdrive... It used to be faster before all the aluminum :-) |
06-16-2014, 04:39 PM | #10 | |
06-16-2014, 05:06 PM | #11 |
Yes open diff helps turn. I am not into crawling with this one so I went with an open diff up front.
08-27-2014, 06:42 AM | #12 | |
Newbie Join Date: Jul 2014 Location: Middle
08-27-2014, 02:36 PM | #13 |
Pebble Pounder Join Date: Apr 2014 Location: Trinidad
Impressive speed!!!
Moving the battery behind the seats sideways. - Similar Threads | ||||
Moving battery | germ | Axial Wraith | 17 | 06-08-2013 07:29 PM |
Moving battery mount | jhedsy | Axial Wraith | 43 | 03-18-2012 01:15 PM |
Moving battery tray to front | nightfiref7efi | Axial Wraith | 10 | 07-30-2011 11:39 PM |
moving battery to front axle? | trevdogg420 | Axial SCX-10 | 4 | 12-21-2009 08:18 AM |
moving battery | ped453 | Newbie General | 1 | 06-05-2009 02:45 PM |
