06-28-2014, 06:02 PM | #1 |
Newbie Join Date: Dec 2013 Location: Darlington
| HELP befor i run this thing over with my semi!
I've been having a lot of trouble with my wraith and getting tired of it breaking every time I take it out had it out today for ten minutes and cooked my castle MMP pro which I'm not sure how it happened. when I first got it I did the plasti dip trick and today I had it in a little bit of water and got hung up on a log in the water (water was up 1/2 way on 2.2s) gave it some throttle to get over it n couldn't. went out and pulled the wraith off and after it acted like a severly dead battery and no reverse. brought it home put my stock esc in and went back out. got bout hour into the run and now I have NO forward or reverse Specs are or WERE Castle creation mamba max pro smart sense ESC castle creation BEC 15/80 pinion spur stock motor 2s lipo stock wraith receiver and transmitter I have a team brood 30t motor I just haven't put back in yet |
06-28-2014, 06:56 PM | #2 |
Pebble Pounder Join Date: Sep 2012 Location: look up, waaay up
| Re: HELP befor i run this thing over with my semi!
Was there any water in your receiver box?
06-28-2014, 07:50 PM | #3 |
Rock Crawler Join Date: Feb 2011 Location: Spur, TX
Not sure if the stock motor comes apart or not, but if it does tear it down and clean it thoroughly. Debree in the brushes can cause them to hang up or worse. If it doesnt come apart wash it out as best you can with clean water, let it dry, then see if it still works.
06-28-2014, 08:43 PM | #4 |
Newbie Join Date: Jan 2012 Location: monroe
Does the steering work ok? I fried a servo once and it wouldn't go forward or back if the servo was plugged into the receiver.
06-28-2014, 09:49 PM | #5 |
Quarry Creeper Join Date: Apr 2014 Location: a land bereft of rocks
Is the motor dead?
06-28-2014, 10:52 PM | #6 |
RCC Addict Join Date: Feb 2014 Location: Mt. Juliet, TN
Sounds like a motor issue.
06-29-2014, 02:48 PM | #7 |
RCC Addict Join Date: Oct 2012 Location: Charleston South Carolina
I would check the receiver. Open up the receiver and put it in a bag of rice overnight.
06-29-2014, 06:35 PM | #8 |
still has steering and im sure it is the esc at least the MMP cause I did get it wet but It was plasti dipped so idk what happened. I got a offer for a trade for a 4x4 slash im sure im going to take the offer cause this thing is breaking something every time I take it out and I am done with this thanks people for your replies on this issue |
06-30-2014, 01:57 AM | #9 |
Pebble Pounder Join Date: May 2013 Location: new zealand
ive had the same type of issue couple days back and it was the receiver had got wet...I had got some water in it and its toast now. wish I could buy just the receiver as I don't need the transmitter
06-30-2014, 05:21 AM | #10 | |
Rock Crawler Join Date: Oct 2013 Location: Wiscasset, ME
| Re: HELP befor i run this thing over with my semi! Quote:
These will both work.. Radio Control Planes, Helicopters, Cars, Boats, FPV and Quadcopters - Hobbyking* Fly Sky FS-GR3C/E/F 2.4GHz Automatic Frequency Hopping Digital System 3 Channel Receiver | |
06-30-2014, 05:34 AM | #11 |
Newbie Join Date: Jun 2014 Location: Carleton
Check the conections to the Motor. I had a problem close to that. I would hit a bump and lose the motor. Steering still worked but would not go. I started pulling on the connectors from the ESC to the motor and found they were lose. and would lose connection. Redid them and have not had a problem.
HELP befor i run this thing over with my semi! - Similar Threads | ||||
help asap befor i buy | hende | Newbie General | 5 | 07-01-2010 09:48 AM |
help befor i order | hende | Axial AX-10 Scorpion | 2 | 01-12-2010 12:57 AM |
A few pics befor it's gone. | wrx-n-ktm | Tamiya Clod Buster | 22 | 12-09-2006 11:49 AM |
