10-08-2014, 03:01 PM | #61 |
RCC Addict Join Date: Aug 2013 Location: Missoula
| Re: Go fast wraith suspension - Turned build thread
I don't think a plastic horn would last 5 minutes. Fixed the problem, for now. Aluminum cased servo and an 1/8" steel plate to hold it down Let's see if it lasts through lunch tomorrow. |
10-08-2014, 03:15 PM | #62 |
Newbie Join Date: Aug 2014 Location: albuquerque
The way I was thinking is a plastic horn has to be cheaper than the case. But awesome on the new parts! Maybe now you can focus elsewhere on the truck.
10-10-2014, 06:15 PM | #63 |
Rock Crawler Join Date: Mar 2006 Location: Dogpatch
Love the use of the sc truck body!
10-29-2014, 04:58 PM | #64 |
It's been a while. Finally wore through the front axle housing deep enough that sticks were getting stuck in the gears Twisted the rear hole out of the RRP one piece lower gear as well. New one installed, I'll look in to 6mm stuff if this happens again. Fresh housing and an alloy cover. Maybe that will help. Body is getting pretty beat, I'll put a Spawn body hacked into a pickup when I can track one down. As she sits now. The Pitbulls just get better and better with wear. |
10-29-2014, 06:42 PM | #65 |
Rock Crawler Join Date: Jul 2008 Location: Pearland, TX
Have you had issues with losing bolts from your beaddlocks? One of my favorite builds on here for sure. Wes |
10-29-2014, 07:32 PM | #66 |
| Re: Go fast wraith suspension - Turned build thread |
10-29-2014, 07:44 PM | #67 |
Crazy, I have lost at least 12-15 in just 4 batt packs. Don't want to locktite them so I can swap to other tires easier. Just have a ton of extra screws on hand to replace them when I lose them. Again, super nice build. Wes |
10-29-2014, 08:18 PM | #68 |
11-01-2014, 05:17 PM | #69 |
I wanna be Dave Join Date: Dec 2006 Location: here
Dose you rig pull hard to on side under instant full throttle, If so any idea how to correct this? The only way i seem able to control the rig from pulling to the side is gradually bringing rig up to full speed.
11-01-2014, 05:50 PM | #70 |
Are you running a rear sway bar? That will help a ton with the torque steer. Wes |
11-01-2014, 06:00 PM | #71 |
11-01-2014, 08:20 PM | #72 |
I don't have a rear sway bar and it pulls straight. Pulls wheelys if the traction is there. The left front tire is off the ground a lot It torques bad, doesn't really bother me though. It it's not a pavement car in any way. |
11-01-2014, 08:37 PM | #73 |
| Re: Go fast wraith suspension - Turned build thread Sway bar (rear) would keep front wheel on the ground |
11-03-2014, 01:36 PM | #74 |
| Re: Go fast wraith suspension - Turned build thread Heard a snap and wouldn't drive straight under power. Nice clean break |
11-05-2014, 06:53 AM | #75 |
RCC Addict Join Date: Feb 2012 Location: UK
Fantastic read. You treat the Wraith like I treat my Traxxas Slashes! Never thought of the Wraith as a basher. (Gave it 5 stars)
11-05-2014, 07:17 AM | #76 |
RCC Addict Join Date: Jun 2013 Location: Port Saint Lucie, Florida
Great thread! Love that you love beating on it as it's meant to be
11-05-2014, 08:30 AM | #77 |
Would love to see some video of you running/bashing this rig.
11-05-2014, 09:51 AM | #78 | ||
| Re: Go fast wraith suspension - Turned build thread Quote:
I'll see what I can do, I need to pick up a GoPro. | ||
11-05-2014, 01:52 PM | #79 |
Some pictures of the dirt pile. This is the dump pile for all the dirt, rocks, fence, asphalt and everything else behind the shop. The tame side. The new side. The steep back side. The curved parking curb measures at 37*. The space between the curbs is only 4" or so. The hill up to the curb is sloppy slick mud and rocks. Gotta clear the pitbulls out from time to time |
12-07-2014, 07:08 PM | #80 |
Rock Crawler Join Date: Nov 2006 Location: Spanish Springs, Nv
Did you end up tuning the shocks different than what you posted? Same set up, or different? |
Go fast wraith suspension - Turned build thread - Similar Threads | ||||
Lucas's Wraith Build Thread | LucasAutomotive | Axial Wraith | 11 | 09-21-2013 09:20 AM |
Evol's Wraith Build thread | ev0l | Axial Wraith | 98 | 09-17-2013 06:47 PM |
aqwik69's Wraith build thread.... | aqwik69 | Axial Wraith | 23 | 09-14-2013 06:50 PM |
Rapid Rhino Wraith #1 - Build Thread | Kobier | Axial Wraith | 5 | 04-10-2012 09:38 PM |
Looking for a picture/thread for turned down stock shocks | Joat | Tamiya TLT Crawlers | 4 | 06-02-2008 08:15 PM |
