06-30-2014, 10:42 PM | #1 |
Newbie Join Date: Mar 2014 Location: Morgan Hill
| VP Currie axle delrin skid plate splitting at mounts, anyone else?
Every time I mount the Delrin skid plate on my new Currie Axle, it's splitting pretty much immediately after I mount it. Does anyone have this skid plate working on their axle? What's the secret to getting this to keep from splitting? Thanks. -CJ |
06-30-2014, 10:45 PM | #2 |
| Re: VP Currie axle delrin skid plate splitting at mounts, anyone else?
Are you over tightening?
06-30-2014, 11:00 PM | #3 |
It's possible on the first one I did, but I made sure on the second one I only went snug.
06-30-2014, 11:01 PM | #4 |
Quarry Creeper Join Date: Jul 2013 Location: Salem/Portland
Mine did it before I even got the bolts against the surface of the delrin skid. I was a little annoyed and vp never responded to my email about it. I gave up and made stainless skid plates. They worked pretty good and were cheap to make. I traded my curries off but the buddy I traded to liked the stainless skids
06-30-2014, 11:31 PM | #5 |
Quarry Creeper Join Date: Jun 2013 Location: San Francisco
Try letting them sit in a glass of hot water before you mount them. It will soften them enough that you can "mold" them to the diff case easily. You should be able to do it with just hot tap water, since the delrin is fairly thin to begin with.
06-30-2014, 11:35 PM | #6 |
Turbodan, I'll give that a shot. I've ruined two of them, and have one left. If it splits, then I'm giving up. |
07-01-2014, 08:20 AM | #7 |
Quarry Creeper Join Date: Dec 2008 Location: Santa Mira
Yes this has happen to me. I have gone through two sets of skid plates and my truck hasn't even hit the rocks yet. There has to be some kind of solution to this. I don't have much faith that they will hold up to the abuse I will put my truck through.
07-01-2014, 09:39 AM | #8 |
Moderator Join Date: Jan 2004 Location: chicago
if vp aint gonna help, go buy a el-cheapo flexible cutting board from the dollar store or some delrin sheet from mcmaster. or just run without the thing and file down that area to get more pumkin clearance.
07-01-2014, 09:55 AM | #9 |
RCC Addict Join Date: Jun 2006 Location: IN THE PIT !!
| Re: VP Currie axle delrin skid plate splitting at mounts, anyone else? didn't even try the stock currie skids - knew they wouldn't last long ! so - i made up some from 16 gauge steel - slides nicely on the rocks ! problem solved ill post up some pics when i get a chance. |
07-01-2014, 10:48 AM | #10 |
Awesome Jerry I would love to see pictures. |
07-01-2014, 01:33 PM | #11 |
Quarry Creeper Join Date: Mar 2008 Location: Redlands
First race this weekend in U4RC, and I had the delrin skid break off right at the top mounting screws. I have some steel at home, might try Jerry's route.
07-01-2014, 01:50 PM | #12 |
I just tried a trick last night and I'll report back. I used shoe-goo with fiberglass cloth on the underside of the skid plate (that faces the pumpkin) to see if it helps to strengthen the plastic. It works like a dream on my drift bodies and the wraith body, so I'm hopeful that it'll be enough to keep the delrin together. VP should probably redesign this, as it's pretty clear that it doesn't work as designed out of the box. |
07-01-2014, 01:52 PM | #13 |
Rock Crawler Join Date: Apr 2005 Location: Monroe, Louisiana
I used steel for my rear axle. It would break every time I backed out of a climb into dirt or rock. The front does fine. Sent from my Desire HD using Tapatalk 2 |
07-01-2014, 02:42 PM | #14 |
i made one out of steel as well, worked great and no issues with catching on anything..but took it off as I am gonna switch to aluminum axle housings soon
07-01-2014, 06:07 PM | #15 |
Quarry Creeper Join Date: Apr 2014 Location: a land bereft of rocks
Use kydex! you can get a 12x12 sheet of amazon for under $10 then use your wife/moms hair dryer to mold it. Plus youll have almost the whole sheet left over. You can make sliders, hood scoops, better diff skids, electronics trays. Kydex kydex kydex haha
07-01-2014, 06:18 PM | #16 |
Interesting. My skids bolted up just fine and have held up great. It's the hardware that gets destroyed from too many hits on the rocks. I took off my front already. The pumpkins are plenty rugged on their own anyway.
07-01-2014, 06:48 PM | #17 | ||
| Re: VP Currie axle delrin skid plate splitting at mounts, anyone else? Quote:
07-01-2014, 09:40 PM | #18 |
| Re: VP Currie axle delrin skid plate splitting at mounts, anyone else? |
07-02-2014, 07:04 AM | #19 |
| Re: VP Currie axle delrin skid plate splitting at mounts, anyone else? heres how i did mine ! 16G steel plate, if there enough call for them i may put them up in the vendor section Rear Front |
07-02-2014, 08:00 AM | #20 |
Rock Crawler Join Date: Sep 2010 Location: Keego Harbor, MI.
| Re: VP Currie axle delrin skid plate splitting at mounts, anyone else? The Cure for me !!!!! Take a heat gun or a hair dryer and set it to high Bend & Hold the Delrin around a golf ball or something similar Take the heat gun/Hair dryer and heat up the Delrin skid to desired shape (Delrin will hold it's shape when cooled down) All Done............. Skid now has the shape of the Housing and is easy to mount and stays in place with out spliting The whole porpose of using Delrin is to be able to slide over the rocks with ease Using aluminum or steel will hang your axles up on the rocks Hope this helps Best Regards Rick |
Tags |
currie axle, delrin, vanquish producs |
VP Currie axle delrin skid plate splitting at mounts, anyone else? - Similar Threads | ||||
Delrin skid plate | 460bronco | Team Losi Comp Crawler | 17 | 11-13-2009 07:33 PM |
Integrated Delrin Skid Plate | Rckcrwlr | Kyosho Crawlers | 11 | 12-27-2008 10:19 PM |
delrin skid plate repair | tat2INDY | Tools, and Procedures | 10 | 10-09-2008 10:04 PM |
Delrin Skid Plate | LEROY | Axial AX-10 Scorpion | 5 | 08-31-2008 10:41 PM |
