07-06-2014, 09:45 AM | #1 |
Newbie Join Date: Jun 2014 Location: Lathrop
| VP SLW alternatives....thicker 12 mm hexes?
I used the search function but couldn't find anything...can someone point me in the direction where I can find a cheap alternative to offsetting my stock wheels so they don't rub on the traxxas links? I saw on RPP these thicker 12mm hexes used on some Traxxas models but I would prefer something in aluminum or alloy...I don't want to spend money on new wheels and tires just yet...I did install the VP titanium links and I noticed that the traxxas ends on the left wheel was almost rubbed completely down to the metal insert. Thank you...sorry if this topic is covered somewhere else. |
07-06-2014, 10:05 AM | #2 |
RCC Addict Join Date: May 2013 Location: Forrestfield, Western Australia
| Re: VP SLW alternatives....thicker 12 mm hexes?
The traxxas are available in ali too. Or there are these +3mm Axial Wraith Aluminum Hex Wheel Hub 3mm wider Black TopCad 23024 Don't be dazzled by all the shiny bling there, some of it's rubbish, especially the links, but the hexs work fine. I think integy does something similar if you search tower or a-main, don't be blinded by the shiny stuff. |
07-06-2014, 11:04 AM | #3 | |
07-06-2014, 09:53 PM | #4 |
Fair enough RPP have these, Tower do to but more expensive. Pro Line PRO-2 Front Clamping Hex for Slash 2WD The Integy version of the Aisatees are out of stock at both Tower & RPP $13.50 gets you 2 thick 2 thin STRC A-main ST Racing Concepts 12mm Aluminum "Lock Pin Style" Wheel Hex Set (Gun Metal) (4) [SPTST3654-12GM] | RC Cars & Trucks - A Main Hobbies |
07-07-2014, 10:38 AM | #5 |
Rock Stacker Join Date: Apr 2014 Location: canada
maybe look at the junfac axle extenders on ebay they will offset 13 or 19mm I think
07-07-2014, 10:39 AM | #6 |
Im too cheap to go slw lol,the junfac reds are 13mm and the blue ones are 19mm,around 30 bucks from what I remember
07-07-2014, 10:49 AM | #7 |
Quarry Creeper Join Date: Jul 2013 Location: Maple Ridge B.C. Canada
Proline makes a wide clamping 12mm hex that are fatter than any of the axial ones they are blue and around $10. Just be careful not to over tighten the clamping screw as it will strip out easy and also cause some slop in your hexes
07-07-2014, 11:47 AM | #8 | |
| Re: VP SLW alternatives....thicker 12 mm hexes? Quote:
07-08-2014, 04:35 PM | #9 |
Newbie Join Date: May 2014 Location: Korea
I got some of the topcad +5mm hexes and found that the axle stubs weren't long enough to install the nut on the wheel. Anyone else experience that?
07-08-2014, 05:25 PM | #10 |
Newbie Join Date: Feb 2014 Location: Bettendorf, Iowa
You could try these from RPP https://www.rpphobby.com/ProductDeta...ode=RC4Z-S0407 I had to open the hole to 7.5mm by about 1/8" on the inside of the wideners so they would fit the Wraith 12mm hubs all the way on. No big deal there. Other than that they work perfectly. |
07-08-2014, 05:59 PM | #11 |
I appreciate all the feedback....I made some quick cash on ebay and bought some Mayhem Engineering Monster's Re-Machined finished wheels. |
07-08-2014, 07:12 PM | #12 |
| Re: VP SLW alternatives....thicker 12 mm hexes? My +3mm are close to out of thread so I figured the +5mm would do that, that's why I didn't recommend them this time. I don't really know what application they'd work in, would have to be a thin flanged nut rather than the stock washer & nyloc maybe.
VP SLW alternatives....thicker 12 mm hexes? - Similar Threads | ||||
Thicker wheel hexes for AX10 ? (8 - 12mm ?) | Pygmy | Axial AX-10 Scorpion | 6 | 07-25-2013 05:13 AM |
how to make a body stilffer/thicker | cdw327 | Paint and Body | 7 | 09-22-2009 09:11 PM |
