07-06-2014, 03:46 PM | #1 |
Newbie Join Date: Apr 2012 Location: Pittsburgh
| wraith glitching
I have an axial wraith that I ran maybe twice. I run nimh batteries so I bought the castle creations usb so I can turn off the lipo cut off. Which I did. It ran fine. Took it out today since winter and it goes then stops. If I push the throttle to get over rocks it just quits. And I have no steering when this happens. Any suggestions? Everything electronic is stock too
07-06-2014, 04:07 PM | #2 |
Rock Crawler Join Date: Jan 2007 Location: Viroqua
Perhaps loose connection between the battery and ESC?
07-06-2014, 04:51 PM | #3 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
| Re: wraith glitching
You're just using it now since winter??? Yes, check connections, hit the motor with some motor spray and oil the bearings.
07-07-2014, 07:59 AM | #4 |
Newbie Join Date: Jun 2014 Location: Sweden
I had the same problem, switched the old motor for a new one and the problem was fixed.
wraith glitching - Similar Threads | ||||
help with glitching wraith | Chief88 | Axial Wraith | 4 | 05-13-2014 09:58 PM |
Timbuk2 wraith edition glitching | Cmarcan167 | Electronics | 1 | 02-09-2014 08:52 PM |
wraith glitching. (PROBLEM SOLVED!!!!) | OhioSuperSport | Axial Wraith | 8 | 03-11-2012 06:52 AM |
Wraith is glitching? Accelerate/reverse issues | Elliott000 | Electronics | 8 | 07-17-2011 05:04 PM |
Glitching | AeroSynch | Electronics | 3 | 03-10-2008 03:39 PM |
