07-10-2014, 10:28 PM | #1 |
Newbie Join Date: Jun 2014 Location: Hampton
| My Cherokee wraith
I bought a poison spider wraith and didn't care for how it performed so I made some changes that made huge differences. Here is a list of my changes. Axial aluminum 25t servo horn Savox 1256 servo Vanquish titanium steering rod and link Gmade piggyback xd 103mm shocks Ms tech droop kit The free wild boar driveshaft fix Vanquish 12mm aluminum wheel hexes Vanquish wheel hubs So far I am loving the truck after the upgrades and look to do more in the future when the budget allows. I snapped some pictures to show its flex. I like the scaled body of the Cherokee and got it to narrowly miss the back window when at full flex. Hope you all like it! Sent from my iPhone using Tapatalk |
07-11-2014, 05:21 AM | #2 |
Newbie Join Date: Jun 2014 Location: Sweden
| Re: My Cherokee wraith
The body looks great on the wraith chassie What is the free wild boar driveshaft fix you mentioned? |
07-11-2014, 06:55 AM | #3 |
In one of Harley's videos he goes over a fix that strengthens the driveshaft by changing the trans output shaft and rear end shaft to female ends. Then take one of the male ends and super glue it into the trans output shaft female end . This allows it to move freely in and out on the rear end shaft. I could post a pic of the finished product if you would like Sent from my iPhone using Tapatalk |
07-11-2014, 07:07 AM | #4 |
Newbie Join Date: May 2014 Location: Korea
TBH, you don't even need to do that. With the stock male and female ends cut a section of parts sprue that's just longer than the make piece. Insert it all the way in, it's a right fit but it'll go. The small bit that sticks out won't cause it to bind but will let you grab it with pliers to remove it if you need to disassemble the joint. No glue required. Been running a castle 2400 on 3s that way and it hasn't even begun twisting.
07-11-2014, 07:35 AM | #5 | |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
| Re: My Cherokee wraith Quote:
07-11-2014, 07:55 AM | #6 |
I did this mod at the very beginning of my getting into the hobby. I have since learned that what you all have said is very true and to just go with the metal driveshafts. I am considering upgrading to some Junfac driveshafts, do you have any experience with those?
07-11-2014, 08:20 AM | #7 |
Junfac shafts are good...haven't had any problems with them yet.
07-11-2014, 09:05 PM | #8 |
Rock Crawler Join Date: May 2013 Location: Somewhere in space
Nice rig, I heard the Junfac shafts are good, I personally use a lot of MIP products but..I would say that the JunFacs are just as good, if not better |
07-12-2014, 02:20 PM | #9 |
Well my next upgrade was decided for me today. I was taking the truck out for a run with the new shocks and snapped the rear driveshaft..... Sent from my iPhone using Tapatalk |
My Cherokee wraith - Similar Threads | ||||
a Cherokee and a Wraith on the Adriatic | atf300 | Videos! | 0 | 10-12-2013 10:15 AM |
wraith xj cherokee help?!!? | Wraith Crawler | Axial Wraith | 4 | 12-14-2012 12:04 AM |
Wraith with Cherokee panels | BLKXJ 96 | Axial Wraith | 10 | 09-17-2012 12:23 PM |
TMXONR's Cherokee Wraith | TMXONR | Axial Wraith | 82 | 04-02-2012 10:13 PM |
P3NGU1N's Cherokee Wraith | P3NGU1N | Axial Wraith | 8 | 02-19-2012 08:59 AM |
