07-13-2014, 01:58 PM | #1 |
Rock Stacker Join Date: May 2014 Location: casper
| timing help
just installed my new HH CM 16t. with the wires hooked up red to red black to black control is backward no big deal fixed that on the remote. But rev is faster how hard it it to fix the timing so its faster forward? Thanks
07-13-2014, 03:18 PM | #2 |
Rock Crawler Join Date: Oct 2013 Location: Wiscasset, ME
| Re: timing help
Options - 1. switch the wires, red to black, black to red. 2. ESC may have rotation settings reverse / normal either way, switch one and reprogram. |
07-13-2014, 03:38 PM | #3 |
Rock Stacker Join Date: Aug 2007 Location: Ventura, Ca.
| Re: timing help
If you have a rtr with backwards diff's, You might consider flipping them and get everything turning in the rite direction
07-13-2014, 07:41 PM | #4 |
| Re: timing help |
07-14-2014, 06:39 PM | #5 |
| Re: timing help
Thats what I'm talking about the customer service from HH does not get any better. John is on it when it comes to help and great product! Motor is fixed and running great. Not as fast as i want but it will work. I will never buy any other motor than one from HH THANKS HH!!!!!!!!
07-15-2014, 11:22 AM | #6 |
Rock Crawler Join Date: May 2013 Location: Somewhere in space
| Re: timing help
The diffs have nothing to do with it, if you reverse the diffs all you're going to do is make it the same way. Simply check your radio trims, then check to see if the motor is wired correctly. Then check to see if the ESC is not reversed with the wires leading to the motor. It's all that simple, don't screw around with the diffs if you have a reverse problem, contact HH if you need more help.
07-15-2014, 02:08 PM | #7 |
What is meant is to reverse the ring gear inside the diff. Switching sides changes direction. This makes all the difference.
07-15-2014, 04:26 PM | #8 |
| Re: timing help Yeah I know what he meant, I had to this on my fastback crawler with ar60's and I had to flip the axle 180 degrees to cut the torque twist and then I had to flip that ring gear, no big deal though. But what I'm saying is that with the problem he's having the ring gears should have nothing to with it..it is a electrical issue...
07-15-2014, 06:13 PM | #9 |
The real problem is the gears..you can compensate electrically but to do it right so nothing electrically has to be reversed you should flip the gears...
timing help - Similar Threads | ||||
MMP timing problems. How do I offset mechanical timing? | Olle P | Electronics | 44 | 12-08-2012 03:59 AM |
How much timing is too much? | WraithCrawler | Electronics | 8 | 12-13-2011 02:13 PM |
Timing question | chops1sc | Electronics | 8 | 03-11-2009 06:57 AM |
Timing a Motor | Harvo | Newbie General | 7 | 12-23-2008 07:00 PM |
timing | badltl510 | Electronics | 5 | 03-04-2007 07:06 PM |
