07-27-2014, 02:57 PM | #1 |
Newbie Join Date: Oct 2012 Location: Olathe, KS
| Locker options
Needing to upgrade the lockers in my wraith as well as needing a set for a big power bouncer project. I would like the locked up spools but they're out of stock everywhere I look same way with the VP and the ones super shafty sells. Are there any other locker options for an AR60 axle other than HR?
07-27-2014, 03:00 PM | #2 |
Newbie Join Date: Jun 2014 Location: Lathrop
Check vendors section for Gripfab lockers...he makes heavy duty spools and lockers that use a grub screw to clamp down on the axles. Supershafty also sells his lockers...here's the link: http://supershafty.com/scx10-axle-mo...ok-locker.html GripFab "Grip-Lok" Locker!! GripFab "Grip-Lok" Locker!! Last edited by btango05; 07-27-2014 at 03:04 PM. |
07-27-2014, 03:18 PM | #3 |
Rock Stacker Join Date: Apr 2014 Location: Houston
| Re: Locker options
I have gripfab spools and I like them |
07-27-2014, 03:20 PM | #4 |
| Re: Locker options
Problem is I cant find the gripfabs in stock anywhere
07-27-2014, 03:50 PM | #5 |
Rock Crawler Join Date: Jan 2012 Location: middle TN
| Re: Locker options
I would wait until the lockedup spools are back in stock. I'm sure it won't be long.
07-28-2014, 01:10 PM | #6 |
Rock Stacker Join Date: Jan 2014 Location: Ramona, Ca.
| Re: Locker options
LU in stock just now, limited quantities...
07-29-2014, 10:08 AM | #7 |
RCC Addict Join Date: Feb 2014 Location: Mt. Juliet, TN
| Re: Locker options
Locked Up spools are hard to beat.
07-29-2014, 11:44 AM | #8 |
| Re: Locker options
LOcked Up RC spools or HotRacing spools.
07-29-2014, 12:31 PM | #9 |
Quarry Creeper Join Date: Sep 2013 Location: Norway
| Re: Locker options
Just fitted Locked Up in my Wraith. They are so tight on tolerances that I had to sand a lot of material off the shafts to get them in. Press fit for sure. Seems absolutely rock solid.
07-29-2014, 12:31 PM | #10 |
Rock Crawler Join Date: May 2013 Location: Somewhere in space
| Re: Locker options
I just threw a set of Locked up spools in my G6 and they have NO play at all. You'll need to grind just a little bit of the axle shaft down to fit cause those spools have absolutely no play at all. Or you could take a mallet and easily tap the axle shaft in the locker..I had to do that as well. In my opinion I'd say get the Locked up over HR or VP.
07-29-2014, 01:07 PM | #11 | |
07-29-2014, 01:22 PM | #12 |
| Re: Locker options |
07-29-2014, 01:57 PM | #13 |
RCC Addict Join Date: Mar 2009 Location: Chilton
| Re: Locker options
I would go with Grip-fab or locked up rc spools I run both and they both are the only ones I have had no issues with so far. You can get the locked up ones from Carterfab.com also if I am thinking right and he usually has them in stock. |
07-29-2014, 08:15 PM | #14 |
Newbie Join Date: Jun 2014 Location: CT
| Re: Locker options
I just ordered 2 locked up spools. I can't wait to see how much abuse they can take Sent from my XT1060 using Tapatalk |
07-29-2014, 08:16 PM | #15 |
Rock Crawler Join Date: Apr 2009 Location: Arizona
| Re: Locker options
I agree...GripFab spool is great! amazing machining, and fit and finish is second to none! |
Locker options - Similar Threads | ||||
Has any one else had there HR locker do this? | MacJamez | Vaterra Twin Hammers | 8 | 05-26-2014 08:07 PM |
What happens if the locker goes out???? | TT17 | Losi Mini-Rock Crawler | 3 | 05-28-2012 07:43 PM |
locker | hodges996 | Axial AX-10 Scorpion | 7 | 02-18-2009 01:36 AM |
Locker | juan916 | Tamiya Clod Buster | 15 | 04-08-2007 12:54 PM |
