Thread: Cornelius, The Hand-me-down IFS Wraith
Old 08-03-2014, 05:50 PM   #1
Default Cornelius, The Hand-me-down IFS Wraith
So this rig has been passed around between few members here in my local club.. It was originally built by EGGBERT. He did an excellent job on this rig. Everything fits and flows nicely. I had built a full tube frame (Aloysius the Ultra4 rig) but with the release of the Yeti, I sold it. When the release date kept getting pushed back, I need to pick up a rig for a local g6 event.. So I picked this chassis and front end up from a buddy. Since then I have put quite a but of work into it. Was going to sell this rig once the yeti came out.. But I like this one too much now!!
I recently ordered around $450 in parts for the front end, replacing pretty much everything that was stock. I am in the process of building a customer rear end for the cage.. Something a little different than everyone else
Here is the parts list:
Chassis:
Cut up wraith frame
HittmanFab rear cage
Eggbert made front end
Exo cut chassis with ifs front end
Rear axle:
Dlux case w/bearing mod
Under drive gears
Ballistic fab diff cover
Front ifs:
Blue Monkey spool
Standard ratio hardened gears
Stock bulkhead
Rpm front arms
Strc front castor blocks
Strc front shock tower
Strc upgraded steering rack
Vanquish steering knuckles
Traxxas heavy duty steel cv shafts (tra6851R)
Lunsford Ti turnbuckles
Rpm rodends
Protek bearings
Transmission and driveshafts:
Stock case with brass inserts
Supershafty motor plate
Duratrax 60t spur
Robinson racing gears
Supershafty 6mm outputs
Fast eddy bearings
Lathed down MIP shafts (little special combo)
Suspension:
Proline shortcourse power-stoke shocks
Chaotic Ti links
Rpm rod ends
Electronics:
3300kv pro4
MMP w/castle bec
Futaba bls157
Futaba rx
Hyperion 3300mah 3s lipos
Tires and wheels:
Vp Enduro wheels
Locked up rc acorn wheel screws
Shift hubs (slims up front, normal in rear)
OTTSIX Gold Voodoo U4 tires
CI Duces wild (tall)
Hittman is offline   Reply With Quote
Old 08-03-2014, 05:51 PM   #2
Default Re: Cornelius, The Hand-me-down IFS Wraith
Onto what people really care about
Rear on left, front on right (center ribs trimmed in the front)
Comparison of what I have
Unmounted w/out foam vs mounted with tall DW foams
OTTSIX tires for life!!!
Old 08-03-2014, 05:51 PM   #3
I will update the thread as I receive parts and move along through the cage. We have a TTC event on the 16th, so I need to get busy
Lmk what you think so far
Old 08-03-2014, 06:26 PM   #4
That IFS Mod. is 1 of the BEST one's that I built, I'm glad you like it pretty good parts list and tires also look BadAss all n' all Great Job Bro
Name:  IFS Wraith 11.jpg
Mudeater67 is offline   Reply With Quote
Old 08-03-2014, 08:01 PM   #5
Have you tryed the voodoos out yet? If so how do you like them?
Tgates is offline   Reply With Quote
Old 08-03-2014, 08:59 PM   #6
www.ottsix.com
....I thought that was Scot's IFS...that I got him for his birthday
crawl-o-matic is offline   Reply With Quote
Old 08-03-2014, 09:19 PM   #7
Thanks mang
I have not. I just picked them up last night. Waiting on some front end parts, and my cage material to show up.
It was. He sold it so he could get the yeti
Old 08-03-2014, 09:29 PM   #8
Love the look of that rear cage chop, what is the strength like with only the single tube at the rear?
Sp3cia1-K is offline   Reply With Quote
Old 08-03-2014, 09:42 PM   #9
There is no strength in it. I will be getting in some material and will be building the back myself. So these pics are far from a finished rig, I just wanted to show how the tires looked mounted up. Thanks for the compliment thou! I think you will like the cage even more once I am done with it
Old 08-05-2014, 10:35 PM   #10
Got some parts in
Old 08-05-2014, 10:53 PM   #11
Looks like you've found a cure for Yeti Fever.
MountainStorm is offline   Reply With Quote
Old 08-11-2014, 11:55 PM   #12
Lightbulb Re: Cornelius, The Hand-me-down IFS Wraith
Anymore updates on your IFS Build? , Little Bro
Old 08-14-2014, 09:05 PM   #13
Yes, but no time to post. Still lots to do before our TTC this weekend. Hopefully finish it up tomorrow.. Sometime before midnight
Will probably post all the updated pics next week
Old 10-09-2014, 02:56 PM   #14
Have you got a PN# for your front spool. I ordered one to work with the traxxas cv shafts like you, but believe I got sent the wrong part as the cv's wont slide up onto the shaft far enough to put the set screws through. Thanks in advance
lawhorn_derrick is offline   Reply With Quote
Old 10-09-2014, 10:28 PM   #15
Had to cut the spool tangs down. I believe 2mm off each side. After that they worked fine.
Old 10-09-2014, 10:31 PM   #16
This rig doesn't exist anymore.. Things changed, taken off, and needing to be sold (complete ifs front end). Switched to a solid axle setup front and rear. Still slammed, so I really like how it drives and handles.
I suck at keeping scale threads updated because I don't have that much interest in scale rigs.. But, I will try my best to get some updates up soon.
Old 10-10-2014, 01:01 PM   #17
Selling the IFS setup huh? *note to self - must resist the urge......*
Looking forward to the updates with solids, etc.
WesTX is offline   Reply With Quote
Cornelius, The Hand-me-down IFS Wraith - Similar Threads
Basket case Wraith roller to U4RC 2.2 rig. Another anti-IFS Wraith. 89redranger Axial Wraith 7 03-30-2014 08:24 PM
