08-17-2014, 01:47 PM | #1 |
Rock Stacker Join Date: Sep 2013 Location: NW arkansas
| MIP drive shafts on extended wheel base
So I finally broke one of my modified drive shafts. They have held up great to 3S roc412 power. The only reason it broke was because the back wheel got plastic twisted around it and I didnt see it and tries to keep climbing. Anyways I'm looking at getting MIP's but I want to know if they will work with a little longer wheel base? Its not stretched yet but I need to know how much longer if any they can handle before I buy some |
08-17-2014, 02:36 PM | #2 |
Quarry Creeper Join Date: Jan 2014 Location: Springfield
The stock length MIP's aren't going to work for an extended wheelbase. If you go to SuperShafty.com, he is selling a longer male shaft by itself that will make things work for you. Sent from the great unknown! |
08-17-2014, 02:56 PM | #3 |
| Re: MIP drive shafts on extended wheel base
Ok thats what I needed to know. Thanks
08-17-2014, 03:05 PM | #4 |
Stock replacement MIP's will work just fine depending on how long you're extending the wheelbase.
08-17-2014, 03:08 PM | #5 |
Between 1/3" to 3/4" most likely
08-17-2014, 03:10 PM | #6 |
Split that distance between the front and rear and it'll be just fine. If you do it all on one end you'll have issues over about 3/8" over stock.
08-17-2014, 04:32 PM | #7 |
Are there any issues that are caused by extending the front also?
08-17-2014, 05:05 PM | #8 |
Not really. This rig has a 13 1/2" wheel base, the front drive line is stock length sitting right at 4 3/4" long end to end. The rear was extended by using a broken MIP cut near the bell welded to another MIP cut near the splines. It measures 5 1/4" long end to end. |
08-17-2014, 05:26 PM | #9 |
| Re: MIP drive shafts on extended wheel base |
08-17-2014, 05:45 PM | #10 |
That's the second time that MIP shaft has been brought up. I'm guessing neither of you that brought it up actually own it do you? It's a great piece if you want to kick one end waaaay out. It's an 1 3/8" longer than an a typical scx shaft so you'd better be ready to really extend it. |
08-20-2014, 05:30 AM | #11 |
I wanna be Dave Join Date: Apr 2014 Location: North Carolina
Try Junfac. They make hardened steel shafts in a range of sizes. My R1 Frankenstein (which uses Wraith axles, an SCX tranny, and ROC 412 3100 on 2s) needed something a bit longer for the rear than the Wraith MIP (which I run in my Wraith), but the extra long male MIP shaft would have been way too long. I chose the 120-150mm Junfac shaft, and it works great. R1 Frankenstein new project |
08-20-2014, 07:04 AM | #12 | |
| Re: MIP drive shafts on extended wheel base Quote:
08-20-2014, 11:34 AM | #13 |
08-20-2014, 11:35 AM | #14 | |
Stick to MIP for sure. Super shafty sells an intermediate length if you need something longer. | |
08-20-2014, 01:07 PM | #15 | |
08-20-2014, 01:19 PM | #16 | |
I used it in my FOFF (14" wb) and had to cut it down. | |
08-20-2014, 05:47 PM | #17 |
MIP drive shafts on extended wheel base - Similar Threads | ||||
extended wheel base Q&A | realsickclown | Axial SCX-10 | 5 | 07-24-2014 03:08 AM |
Extended drive shafts optitions for peeps that are exting the wheel base on their TH | lazynocturnal | Vaterra Twin Hammers | 7 | 06-06-2013 02:50 PM |
Extended Wheel Base | Tedro | Axial SCX-10 | 6 | 03-15-2013 09:40 PM |
AX10 MIP C Drive dig drive shafts in stock! | RPP Hobby | RPP Hobby | 1 | 12-03-2009 10:50 PM |
