08-17-2014, 07:19 PM | #1 |
Newbie Join Date: Sep 2008 Location: Upper Deerfield
| Wraith motor
I've been running both 17 & 27 turn brushed motors in my Wraith. The problem after a fairly short run time they are getting extremely hot. I've destroyed 2 motors so far. Also have the 80 tooth spur and 18 or 20 tooth pinion. Any ideas what I should be running? Don't want to run brushless, any help is appreciated.
08-17-2014, 07:27 PM | #2 |
Rock Stacker Join Date: Jan 2013 Location: St George
| Re: Wraith motor
What are you doing with it? Crawling? Bashing? Chasing the neighborhood kids?
08-17-2014, 07:37 PM | #3 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
| Re: Wraith motor
Go with a bigger spur and smaller pinion. 80/20 is too high imo.
08-17-2014, 07:50 PM | #4 |
| Re: Wraith motor
Trail riding with it, a lot of slow crawling
08-17-2014, 07:57 PM | #5 |
| Re: Wraith motor
You need to gear it down. The motor is straining all the power it can give.ether get a higher turn motor, gear down or go brushless.
08-17-2014, 08:27 PM | #6 |
| Re: Wraith motor
get that 80t spur out of there. Get an 87t. and try 16t pinion to go with it.
08-17-2014, 11:08 PM | #7 |
Pebble Pounder Join Date: Apr 2014 Location: Trinidad
| Re: Wraith motor
80/20 = 4.00 ratio 80/18 = 4.44 ratio 80/16 = 5.00 ratio 87/18 = 4.83 ratio Changing the pinion gear will have a much bigger effect on the overall ratio. You could keep that 80T spur and run a 16T pinion.. I run a 87/18 setup and my temps remain stable with long runs + occasional hard blasts on hills etc. If you are a lead finger, gear down further slightly to protect the motor. The factory 20T will last reasonably long on a geared down 2S setup. If running 3S, try a Traxxas 21T 550 motor instead. |
10-15-2014, 12:03 PM | #8 |
Newbie Join Date: Sep 2014 Location: FRG
| Re: Wraith motor
What kind of ratio is best for some crawling but mostly trails
10-15-2014, 05:04 PM | #9 |
| Re: Wraith motor |
10-15-2014, 10:08 PM | #10 |
| Re: Wraith motor |
Wraith motor - Similar Threads | ||||
Wraith motor | D.Giroux | Axial Wraith | 5 | 06-30-2014 04:12 PM |
Wraith Motor for 3S and BR-XL | BennyTRD | Axial Wraith | 16 | 08-19-2011 02:31 AM |
