08-18-2014, 06:30 PM | #1 |
Quarry Creeper Join Date: Jun 2012 Location: pomona
| over under question
I'm putting Grip Fab lockers on my Wraith axles and it was suggested to me by several people to put heavy duty gears in which makes sense. (Thanks ZippoMan, grscivic, HDMM and Cronk) My question is what is the advantage of over-under gearing and is it a good idea. And if the gears are 38-13 and 36-14 am I correct in thinking that the 38-13 would go in the front axle. Thanks for the help.
08-18-2014, 06:33 PM | #2 |
Quarry Creeper Join Date: Aug 2011 Location: Antioch by a rock!
| Re: over under question
No I will jump in here and say that the lower the gears are in the rear the better dig effect you have in the rocks.
08-18-2014, 06:34 PM | #3 |
That means 43/13 in the rear
08-18-2014, 07:34 PM | #4 |
RCC Addict Join Date: May 2013 Location: Forrestfield, Western Australia
It depends on what your doing with it, crawling & trailing go under/overs, helps with steering & climbing. Fast running U4 style seems most guys run run the same ratio front & rear to avoid drive line bind, a lot look to be running the underdrive set both ends they have the deepest gear mesh & strongest tooth profile. Good info about gear set selection starts here Wheels7 handmade Ultra class car with a DLUX twist |
over under question - Similar Threads | ||||
Tire foam question. WARNING!!! Noob question! | tokdl | Tires and Wheels | 6 | 05-07-2014 10:55 AM |
Drive way too fast question and front locker question. | Mr.JayDeeM | Axial AX-10 Scorpion | 15 | 02-07-2012 09:19 AM |
clearance question and articulation question | axialnut | Newbie General | 17 | 09-24-2010 09:55 PM |
Simplefied question for pervious question. | Mudsy | Tamiya Clod Buster | 2 | 05-03-2009 09:59 AM |
