Thread: Binding in Front Axle
Old 08-25-2014, 06:19 PM   #1
Default Binding in Front Axle
Have installed the heady-duty pinion/ring (13/3 in my stock/plastic front axle. Have added beef tubes and locked up rc spool. The gears are not meshing correctly. Any idea what I have done wrong? Did the same to my rear axle, but no issues there. The stock plastic axle housing "looks" straight, but something is up. Have also replaced all bearings.
Something is messing with the gear mesh with the pinion and ring gears.
Any ideas?
Thanks in advance.
Gossamer_G30 is offline   Reply With Quote
Old 08-25-2014, 06:45 PM   #2
Default Re: Binding in Front Axle
Unmount the chubs / knuckles and pull axles out the locker, see if the ring and pinion spins freely. If it does, it could mean interference between the beef tubes, axles and locker.
Or try slackening the bearing caps and see if it frees up. You have to separate everything and reassemble piece by piece until the binding issue shows up. You installed too many new parts to track it down in one shot..
3stage is offline   Reply With Quote
Old 08-25-2014, 07:01 PM   #3
Thanks 3 stage. Will give that a shot.
Old 08-26-2014, 01:02 AM   #4
Natedog's Avatar
This and may need a little shimming, although my Wraith axles needed way less than SCX axles.
Old 08-26-2014, 07:31 AM   #5
Have to shim your pinion just like in a 1:1 until you find the happy spot. Haha. But try pulling the shafts first, doubt that's the issue though.
crawler nut is offline   Reply With Quote
Binding in Front Axle - Similar Threads
SCX10 Front Axle Jumpy, binding? 123nanez Axial SCX-10 8 11-29-2015 12:57 PM
CVD front axle binding when turning Odd-M Axial SCX-10 9 08-19-2014 01:44 PM
front axle binding 1lowta Axial Wraith 15 07-13-2013 08:54 AM
Front axle binding rottenbelly Axial AX-10 Scorpion 7 01-15-2009 07:16 PM
Nylint front axle binding/stripping TLTCrawlin General Crawlers 2 02-05-2006 12:53 PM
