09-09-2014, 12:19 AM | #1 |
RCC Addict Join Date: Aug 2014 Location: Virginia, Near DC, USA
| Twisted the steering knuckles on my Wraith.
So, this happened: Kinda inevitable, I suppose, but what can I do to prevent it happening again? I was thinking of getting the Vanquish scale steering knuckles, because they have two mounting points, which should prevent the steering link from being able to twist the knuckle. Are there any other options I should consider? Last edited by fyrstormer; 03-30-2018 at 12:13 AM. |
09-09-2014, 12:21 AM | #2 |
Pebble Pounder Join Date: Mar 2011 Location: Wales,UK
| Re: Twisted the steering knuckles on my Wraith.
Not sure what brand you had but I suspect that the likes of GPM Racing /topCad /integy are all pretty much the same.
09-09-2014, 12:37 AM | #3 |
It was TopCAD, but unless someone has invented some magical kind of aluminum that's as strong as steel, I suspect something like this will happen to any aluminum knuckle with this design eventually. I mean, I'm running the highest-torque servo I could find, with no servo-saver and titanium linkages, so there is no part of the steering system that will gracefully absorb shock to the steering system. Speaking of which, does anyone make piston-style servo savers that fit in place of the steering link? |
09-09-2014, 12:48 AM | #4 |
Rock Stacker Join Date: May 2013 Location: Brownsburg, IN
I have the STRC ones and they have held up with no issues. New STRC Precision Aluminum Steering Knuckles Axial Wraith STA80061BK | eBay They make them in the green as well but not sure how well the color will match up with the TOPCAD green.
09-09-2014, 12:51 AM | #5 |
I saw those. Why do the stock steering knuckles have those extra mounting points behind the axle, which the Wraith doesn't use? And why did STRC copy them? They serve no purpose on this vehicle. Stuff like that annoys me.
09-09-2014, 03:28 AM | #6 |
| Re: Twisted the steering knuckles on my Wraith. Gmade / Junfac used to do a couple , normal rated at 1.2Kg/mm and a hard version at 1.7Kg/mm, but they are discontinued I think. They were 135mm eye to eye so maybe not suitable for a Wraith anyway.
09-09-2014, 03:52 AM | #7 |
Newbie Join Date: Aug 2013 Location: Australia
Pretty sure there are different grades of aluminum from soft to hard. A lot of good quality parts are made from 7075 aluminum which I was told is like aircraft grade aluminiun.
09-09-2014, 06:03 AM | #8 | |
Pebble Pounder Join Date: May 2014 Location: fernandina beach
| Re: Twisted the steering knuckles on my Wraith. Quote:
For buying hop-up parts, I like to think of it this way...there's a guy just like you working in a US factory making parts from high grade aluminum that needs to pay his bills and support his family, just like you need to. | |
09-09-2014, 06:08 AM | #9 |
I've bought the Stage 1 Vanquish kit - it arrived yesterday, looks pretty good quality - Amain hobbies shipping was reasonable, and I avoided the dreaded UK import duty - quite happy with the end result. I've used KMRacing (appear 99.9999% the same as STRC) parts on both my Cr-01 builds and I've been ahppy with those too.
09-09-2014, 10:27 AM | #10 | ||
Those are some cheap Chinese brand low grade aluminum and that was going to happen sooner or later. Buy the new VP double shear mount type knuckles and be done, I'd buy matching c-hubs while you're at it. | ||
09-09-2014, 04:22 PM | #11 |
| Re: Twisted the steering knuckles on my Wraith. You can use them instead of using the Ackerman mounts. I just switched the left and right knuckles and casters so that the double tabs would be facing forward and it still keeps the camber the same.
09-09-2014, 05:34 PM | #12 | |
I suppose that's why the more expensive brands use bolt-on steel shear-mounts. I just wasn't expecting this to happen, because I have GPM or TopCAD hubs on all my other vehicles and they've never bent even a little. Obviously I forgot to factor-in the effect of having no servo-saver. | |
09-09-2014, 05:36 PM | #13 | |
STRC will probably win, because they make green parts and I already have their green shock caps, and they use bolt-on steel shear-mounts. I guess I'll just suck it up and deal with the extra bits hanging off the back, unless someone can persuade Vanquish to make a run of green steering knuckles. Last edited by fyrstormer; 09-09-2014 at 06:16 PM. | |
09-09-2014, 06:20 PM | #14 | |
Rock Crawler Join Date: Aug 2011 Location: tri cities
Its like a car, there is high quality cars that last a long time and there are some, like you Yugo, that should have never been made. | |
09-10-2014, 08:01 PM | #15 |
I addressed different grades of aluminum in a subsequent post.
09-10-2014, 09:00 PM | #16 |
Rock Stacker Join Date: Aug 2014 Location: Somerset
Wish I had known you needed green sooner. I just stripped a set of strc over the weekend and polished them to sell as I figured nobody would want the green.
09-11-2014, 01:55 AM | #17 |
Damn. Oh well.
