09-16-2014, 08:11 PM | #1 |
Newbie Join Date: Aug 2014 Location: Naples
| Wraith Clicking/Slipping in front end
My wraith makes a clicking noise or like it's slipping on one of the front wheels on moderate acceleration. The pin is not loose on the wheel or any of that. What could be the problem?
09-16-2014, 08:22 PM | #2 |
Newbie Join Date: Jul 2014 Location: callahan
| Re: Wraith Clicking/Slipping in front end
The end of the axle shaft and/or locker could be ore out allowing it to slip.. Time to tear into the axle for an inspection.
09-16-2014, 08:42 PM | #3 |
Appreciate it. I guess that's what I shall do. Are there any cheap tricks to making to front rear ends any tougher? |
09-16-2014, 08:48 PM | #4 |
The wraith has a sidewinder esc, 4 pole. 3800 kv motor, 10 amp external bec, rc4wd 2 speed trans, Mip center shafts etc.
09-16-2014, 09:37 PM | #5 |
I wanna be Dave Join Date: Sep 2009 Location: n. palm beach
If you don't already have them, get the HD gears. Another thing is to shim the ring and pinion gears. It'll take the slop out of the axles. As I'm looks for a set my self, please post up where we can order a set. Thanks guys. |
09-16-2014, 10:00 PM | #6 |
Yes gota shim wraith ring and pinion . If yoy don't the have tons of lash and will make noisd, and wear prematurely
09-17-2014, 12:08 PM | #7 |
Thank you very much guys. Is there some kind of a diagram anybody has that shows where and how many shims to put in each place? Also without tearing it apart I messed with it a little more today. The front two wheels slip very easily almost enough do the truck is 2wd. You can hear it click. Another thing is I can take the two front wheels one in each hand and turn them opposite ways. It take some force of course but then you hear it click and they will slip. My wheels are staring to lean in and get wobbly on the front as well. Looks great! Last edited by THX_138; 10-01-2014 at 10:49 PM. Reason: Minute apart posts merged |
09-17-2014, 03:43 PM | #8 |
Pebble Pounder Join Date: Mar 2011 Location: Wales,UK
If you can turn the wheels in opposite directions then as a minimum the locker block or plastic diff casing have failed, or the splines on the end of the axles are slipping in the diff, or you've sheared an axle - if both wheels are tilted then it sounds more diff related. Either way you'll need to dismantle the axle for investigation.
09-17-2014, 05:25 PM | #9 |
Rock Stacker Join Date: Apr 2014 Location: Mobile
If your differential is busted, I highly recommend the Locked-Up RC "FI" Spool. Had the same issue. No slop now.
09-17-2014, 07:59 PM | #10 |
Awesome. Appreciate all the help guys. I'm going to tear into it tomorrow and see what's going on.
09-18-2014, 07:38 AM | #11 |
Opened it up, the diff is good I have the vanquish floating locker in it, dog bones all good. Both front wheels don't move just grinds and has only 2 wd unless you go very very slow
09-19-2014, 01:38 PM | #12 |
Rock Crawler Join Date: Dec 2011 Location: Blacksburg
your axle shafts that go into the lockers might be rounded off enough to let them slip in the locker.
09-20-2014, 11:52 AM | #13 |
Newbie Join Date: Dec 2005 Location: York, PA
Pics would help of all of the above mentioned areas. Might help us see what your problem is.
Wraith Clicking/Slipping in front end - Similar Threads | ||||
Rear end slipping | scrubby | Losi Mini-Rock Crawler | 14 | 07-18-2012 05:19 PM |
rear end is slipping, clicking noise | zackattack | Axial AX-10 Scorpion | 9 | 05-01-2009 07:35 PM |
diff clicking, pinion slipping | BlueMonster | Tamiya TLT Crawlers | 7 | 01-01-2007 03:38 AM |
