09-22-2014, 06:08 AM | #1 |
Newbie Join Date: Jan 2013 Location: South Africa
| Hot and weak wraith
Hi When I crawl hard and long my wraith looses power (gets weaker doesnt cut out, its as if the battery is empty when I change the battery still the same. And my motor and ESC is hot as hell. My friend scorpion crawls at the same place same time and its cool. When I leave it for a while and everything is cooled down then the car is back to normal. My setup is Diffs 13/38 Pinion and spur 16/87 Esc Axial AE2 Motor Axial 27t brushed Battaries 2s lipo Wheels 2.2 Proline Chisel If I understand Harleys threads correct my setup is right for what I want to do with my wraith, just crawl and enough speed to get up a hill. Please help me. |
09-22-2014, 06:58 AM | #2 |
Pebble Pounder Join Date: Mar 2011 Location: Wales,UK
| Re: Hot and weak wraith
Well you're gearing looks pretty good. Check the spur/pinion mesh - if its too tight with will heat/overheat the motor. Slipper clutch - if its slipping it will make the motor work harder for forward traction - tighten the nut either right down, or for a little safety in the drivetrain tighten it fully and back off 1/3rd of a turn. Other than that it could be restrictions in the drivetrain - heavy auto grease in the diffs won;t help, partly seized bearings, overtightened wheels etc etc Its a case of just workign your way throguh it - spin each wheel by hand off the ground to feel for any roughness or tightness. |
09-22-2014, 08:07 AM | #3 |
2013 2.2P Nat. Champion Join Date: Sep 2009 Location: BorderLine Crawlers Season 3 is on!
| Re: Hot and weak wraith |
09-22-2014, 08:04 PM | #4 |
If you want to do extended stressful crawling with a cheap sealed can then your going to have to gear lower. Yeah, it sucks to loose what little wheelspeed you have, but it's going to be the most effective way at lowering the temps of your motor/esc. Truth is, the Castle-based ESC can probably take the heat. It's just working hard because the motor is working hard. Motors tend to not take kindly to overheating. Anything above about 160*F can cause permanent damage to the motor. I had to run 12/87 gearing with various cheap 27 turn motors to keep them from practically melting on the rocks. If I was woods bashing/trailing I could get away with the same 16/87 that you are running. What is your friends scorpion geared at? IIRC mine came geared stock at 87/14 and it is a lighter smaller truck than a Wraith. |
09-23-2014, 07:19 PM | #5 |
Pebble Pounder Join Date: Apr 2014 Location: Trinidad
I'd check for binding as well, make sure all bearings are spinning smoothly and not seizing up. I run 87/18 on a stock 20T (2S lipo) and it can take a lot of abuse without getting out of control temperature wise. |
Hot and weak wraith - Similar Threads | ||||
Hot Wraith Project | Robny | Axial Wraith | 7 | 12-15-2013 12:03 AM |
Hot Wraith | Tiger 88 | Axial Wraith | 12 | 06-30-2013 01:56 PM |
my wraith reverse is slow and weak.. | gordesky1 | Axial Wraith | 2 | 12-04-2012 04:11 PM |
How Hot Are You Running Your Wraith? | alexchen86 | Axial Wraith | 6 | 04-16-2012 09:06 AM |
Totally hot, hot, hot Melons inside! | hvydty1 | Chit Chat | 6 | 06-03-2009 08:48 PM |
