09-29-2014, 11:36 AM | #1 |
Newbie Join Date: Sep 2014 Location: Saratoga Springs
| Beef tube help?
I bought a set of beef tubes for the front and rear of my wraith. I read somewhere that they worked for the front and rear. Front went smooth for me. When trying to do the rear I put the tubes into the axle housing. Then when trying to install the rear axles into the housing with the beef tube already inserted into the housing the axle shafts will not fit into the tubes. The Flange part at the end of both sides of the axles seem slightly to large to fit into the beef tube in the housing.Can anyone give me some pointers on how you installed yours? Am I correct that beef tubes are compatible with the rear of the wraith?
09-29-2014, 11:39 AM | #2 |
Rock Crawler Join Date: Jun 2013 Location: Knox, IN
| Re: Beef tube help?
You have to pull the axles and use a dremel to trim down the flanges that keep the beef tubes from going in. I have them on both ends of my Wraith, even though it is 4WS!
09-29-2014, 12:04 PM | #3 |
| Re: Beef tube help?
I didn't read anything about that in any of the beef tube thread or anywhere else. Kind of dissapinting because I thought they were a direct fit. If I choose to attempt this could I trim the flange down to much or can I pretty much remove the whole thing? What dremmel attachment would you suggest? Is this what all others have had to do to get their beef tubes to work in the rear? |
09-29-2014, 12:08 PM | #4 |
Pebble Pounder Join Date: Aug 2013 Location: Jacksonville
| Re: Beef tube help?
I thought this thread was about something completely different from what it actually is. |
09-29-2014, 12:09 PM | #5 |
Pebble Pounder Join Date: Dec 2013 Location: yakima
| Re: Beef tube help?
Yep you have to trim the flange. I had to do the same thing. Just chucked the axles up in my cordless drill and used a file on the flange till they slid in the tubes. Just go slow till they fit.
09-29-2014, 12:32 PM | #6 |
RCC Addict Join Date: Aug 2012 Location: The Garage!!!
| Re: Beef tube help?
60grit round drum works great!
09-29-2014, 01:02 PM | #7 |
Rock Stacker Join Date: Jan 2014 Location: Ramona, Ca.
| Re: Beef tube help?
x2 on setting them in the chuck on a drill then running them on a file, files them down evenly. If you read far enough on the beef tube thread it does mention having to do it. Read through the whole thing, and the long side will seem to have some in and out slop after doing this but the thread says that is normal.
09-29-2014, 01:04 PM | #8 |
| Re: Beef tube help?
Ok. Thanks for the feedback. I guess I'll try a 60 grit dremmel attachment to make it work. I still think this should be added to the beef tube website so people know this before purchase. So when sanding only remove enough of the flange to fit it into the beef tube? Not the whole flange? |
09-29-2014, 01:08 PM | #9 |
| Re: Beef tube help?
I took off enough til it just fit, don't think it will hurt if you go a little too far though.
09-29-2014, 04:08 PM | #10 |
| Re: Beef tube help?
So regular 60 grit sand paper will take enough off? I'll use a drill chuck for the shafts so it does it evenly. |
09-29-2014, 04:51 PM | #11 |
Pebble Pounder Join Date: Apr 2014 Location: Trinidad
| Re: Beef tube help?
Normal issue with beef tubes. Drill + sandpaper is the recommended method from what i've read. I have a set of beef tubes as well, just to find some time to get them installed.
10-09-2014, 11:40 AM | #12 |
| Re: Beef tube help?
Got them all in. Thanks for all the help everyone.
Beef tube help? - Similar Threads | ||||
Beef Tube Questions | silverado2004 | Axial SCX-10 | 21 | 01-12-2015 10:43 AM |
help with beef tube install!! | wsmb | Axial Wraith | 8 | 01-23-2014 06:53 PM |
Beef in Yer Rear! to Tube? or NOT to Tube? | Big Tex | General Scale Talk | 29 | 01-08-2014 03:56 PM |
Beef tube ? | jcsaxial | General Crawlers | 3 | 08-28-2012 02:15 PM |
