10-12-2014, 05:35 PM | #1 |
Newbie Join Date: Oct 2014 Location: rohnert park
| new to this and need help!!!
So im having some problems ive blown 2 motors in less then 5 minutes of run time im running the lipo lectron pro 5200mah 50c. I have a stock esc and a savage steering servo. Im just woundering what motor and esc combo would be able to keep up with my lipo. The first motor was just stock and the second was a titan 12t. Im thinking about going to brushless blasstic 13.5 but dont want to spend the money and have it burn up again. Any help would be great. Thank you. |
10-12-2014, 05:47 PM | #2 |
RCC Addict Join Date: Aug 2012 Location: The Garage!!!
| Re: new to this and need help!!!
You can upgrade both esc & motor if ya want too! You can just replace the motor(I think 15t is lowest turn rated for Ae-2)& run a BEC! IMO I would... A. Go with brushed esc(holmes hobbie BRXL waterproof)& HH 13t sport trailmaster motor! B. Brushless??? Mamba max(castle)or rs pro(tekin)esc with a TEKIN roc 412 3100kv or HH trailmaster 3100kv but beware when you go brushless so does all stock drivetrain I'm not sure with servo unless ya talkin bout a savox, if so BEC will add max torque without pulling power from esc!(Set at 6.0v) Hope this helps??? |
10-12-2014, 06:45 PM | #3 |
Rock Stacker Join Date: Oct 2014 Location: Ft Campbell
What cell count is your lipo?
10-12-2014, 07:15 PM | #4 |
Rock Crawler Join Date: Jul 2009 Location: Victoria Australia
What gearing are you running.
10-12-2014, 07:32 PM | #5 |
Pebble Pounder Join Date: Apr 2014 Location: Trinidad
The 12T Titan requires proper break in before using. No drag brakes to be used during break in period and it should be run at higher speeds during that time. Try to avoid low speed crawling, full throttle take offs etc
10-12-2014, 09:17 PM | #6 |
Quarry Creeper Join Date: Aug 2013 Location: South Crawlolina
In order to diagnose the problem, we need the following information: ...and also we should add... Are you crawling, bashing, mudding, high speed running, etc? Are you running a BEC? IF so is it the ESC's internal BEC or is it an external BEC? |
