Thread: wheel weight
Old 10-22-2014, 06:06 PM   #1
Default wheel weight
i am currently in the process of rebuilding the whole front axel it sucks to be down this long as i can't just buy every thing i need at one time and I'm tired of just spending money to get by and make it run my question is i only have 2.5oz of weight inside each tire and that seems to work good for me but i keep snapping axel shafts been through 2 sets of dog bones and a set if axial cvs they broke i believe cuz my c-hub broke any how are running knuckle weights the way to go seems like it will be a lot less stress on the shafts and if so who make the best ones i will be using VP c-hubs and knuckles...... thanks for the help
wyomingcrawler is offline   Reply With Quote
Old 10-22-2014, 08:57 PM   #2
Default Re: wheel weight
RCBROS makes some nice ones.....are you using any beeftubes by chance?
lawhorn_derrick is offline   Reply With Quote
Old 10-22-2014, 09:19 PM   #3
yep have them in the rear with all VP stuff and stock shafts and HD 43/13 under drive gears been great for over six months...... front beef tubes will be here tomorrow for the front. why do you ask?
Old 10-23-2014, 02:28 AM   #4
I run 2x batteries in my wraith...no need to weight wheels, actually we back to plastic type wheels from alloy and steel and haven't broken any driveline parts in ages
skidtoy is offline   Reply With Quote
Old 10-23-2014, 04:33 AM   #5
Cool Re: wheel weight
Wheel weights are a must in my opinion. For crawling that is.
gwcrawler is offline   Reply With Quote
Old 10-24-2014, 11:48 AM   #6
Because if you didn't have a tube in the front it might be all you need without the need for knuckle weights
wheel weight - Similar Threads
wheel weight vs knuckle or axle weight vs creative weight distribution tech712 Axial SCX-10 16 11-04-2014 01:04 PM
Wheel weight vs 1:1 should scalers use wheel weight juswin24 1.9 Scale Rigs 29 04-08-2012 07:51 PM
Wheel weight / axle weight advice JeffK11 RC4WD Bully 6 03-15-2012 03:30 PM
Wheel weight Vs Axle weight. Simon.O. General Crawlers 33 02-15-2010 07:01 PM
Wheel weight vs. chassis weight ratio OR spung/unsprung bias solomon7 Tires and Wheels 15 08-02-2008 06:26 PM
