Thread: Radio reception cutting out after esc/motor upgrade
Old 10-26-2014, 01:28 PM   #1
Default Radio reception cutting out after esc/motor upgrade
HI everyone,
I put the stock esc and motor from my exo into my wraith and since then if it gets about 20 ft away it will stop responding to the controller. I'll move a foot closer and it'll work again. any ideas? has anyone ever had this issue? thanks!
djb2 is offline   Reply With Quote
Old 10-26-2014, 02:08 PM   #2
Default Re: Radio reception cutting out after esc/motor upgrade
Most likely damaged the antenna on the receiver. I've been through several for that reason.
The flysky GT3E works with the axial transmitter, they're like $9 on amazon.
maslin is offline   Reply With Quote
Old 10-26-2014, 02:49 PM   #3
Recalibrate the esc. The same thing happened when I switched to a new system.
lostonthetrails is offline   Reply With Quote
Radio reception cutting out after esc/motor upgrade - Similar Threads
SCX10 Motor/ESC upgrade stompjrkz400 Axial SCX-10 26 01-04-2012 10:01 PM
upgrade servo or motor/esc? el_Fernando Losi Mini-Rock Crawler 7 03-29-2010 09:30 PM
Looking to upgrade stock esc and motor mikegigabyte Electronics 1 12-15-2009 09:13 PM
Should I change or upgrade my motor/esc? acrosteve Electronics 13 08-06-2009 07:59 AM
RTR poor radio reception amstel78 Axial AX-10 Scorpion 6 09-14-2008 01:05 PM
