New to the Rc and forum world advice please Ok so i have an actual Jeep wrangler that i rock crawl with and i wanted an rc one as well since i discovered that there was such a thing. Well i finally got one and my first one is this Axail Wraith Rock racer. Within first 5 minutes of wheeling it i stripped out the stock servo... Replaced it with one that won't strip out supposably ran about $60 and is waterproof. Now after a couple of days out heeling with it i burnt up the stock motor... I am rough on all my toys. So now i am overwhelmed with the amount of info on motors gears and sorry for my ignorance but what does esc stand for?? I don't race it but i wheel it on rocks and rock piles and basically anything that looks challenging. So my questions would be what motor recommendations gearing should i get and also am i gonna need to get a different battery than the 2 cell lipo i have now??? Please dumb it down for me as much as you can i learn quick but like i said the info is overwhelming and all the cool new shiny stuff i can put on it my brain is already fried with stuff i want... So first of all what do i need to get running reliable again i don't wanna break real quick i like to replace with quality and an upgrade.. Hope this is in the right place and thanks for the info in advance"thumbsup" |
Re: New to the Rc and forum world advice please ESC stands for electronic speed control, in a nutshell, get yourself a holmes hobbies torquemaster pro or expert 35t motor and you can use your stock ESC. Stay with your 2s lipo for now...change the pinion gear to a 14t gear if you stay with the 48p spur gear. you can swap out to a 32p spur and pinion, in which case you would want to go with 56t spur and a 10-12t pinion depending on your preference. You may need to add in a BEC for your steering servo if its torque is over 200oz or so I would upgrade to beeftubes and aluminum knuckles,chubs and lockouts..strc is a pretty decent brand.... steering links changed to aluminum, or stainless steel..many vendors have these... front and rear links either aluminum or stainless steel, avoid the ones that have the pivot balls built in, use ones with replaceable ends. get a set of MIP driveshafts and be done with that... replace the internal trans gears with HR steel gears convert the wheels from pin hubs to hex hubs as you run it more you will want to do other upgrades such as going with a brushless setup and 3s lipos..universal joint axles...shocks..etc.... |
Re: New to the Rc and forum world advice please I could offer my two pence but it said much much better in the Stickies at the top of this forum. :) You bought a great truck. I run a 27 turn motor though for reference. :) |
Re: New to the Rc and forum world advice please Quote:
Re: New to the Rc and forum world advice please hey thanks for the info i will get on that immediately!! But um..... what is a bec??? |
Re: New to the Rc and forum world advice please |
Re: New to the Rc and forum world advice please Holmes Hobbies LLC It is used to regulate voltage to your servo in most cases to assure max torque at all times not pulling juice from esc. I run a bec on all my rigs! |
Re: New to the Rc and forum world advice please You do this long enough, you wind up being an electrical engineer ;) I would suggest investing in a good soldering iron and learn how, you're going to need it =) |
just install 12mm wraith hexes over the existing pins, easy as that. then you can run any 12mm hex wheel...the stock poison spyder wheels will need the pin hubs changed out to hex hubs from VP or other aftermarkets that will fit.. |
Re: New to the Rc and forum world advice please [QUOTE=allanon1965;4931069] Quote:
Ok, thanks. I was a bit confused by the pins/setup of the poison spyder wheels. |
Re: New to the Rc and forum world advice please Sorry for asking this, since this threat isnt mine, but do we have to use a bec when we have a 2S lipo and a non digital servo our even with digital servos we have to use the bec? |
Re: New to the Rc and forum world advice please "YES"You need a bec on everything IMO! 2s-6s don't matter its a must on most servos even stock to get the most torque plus keep from causing power loss to other components since battery is running motor,esc,lights,winch etc...some esc's come with internal bec's but don't set voltage to one or more servo's,winches,lights blah blah blah so when reading the STICKY'S(electronics,newbie,general,scx,wraith,etc ... at the top of any forum page will answer almost any question you have & SEARCH will complete any answer! "thumbsup" |
Re: New to the Rc and forum world advice please Dont sweat it, we've all been in your shoes, utterly confused and overwhelmed by the choices in front of us. You'll get there! Next thing you know, you'll be advising one of your friends on something RC and have this moment of "Hey wait. I actually know what im talking about now!" :ror: The advice given here so far is A+ quality, so I dont have much to add outright. As for this question: Quote:
Suffice to say, you dont NEED one to survive, but it certainly will help a lot. Much in the same way that you dont NEED a bulletproof vest to survive getting shot, but it sure helps alot ;) |
