11-01-2014, 09:46 PM | #1 |
Newbie Join Date: Nov 2014 Location: Phoenix
| Simple noob questions on a stock Wraith.
Hey all, I have a stock wraith and I was planning some possible upgrades for the future, but I want to see if there are any secrets to the whole set up I'm missing as this is my first crawler. This is my list so far: VP 8pc Ti Links VP Zero Ackermann Racing Arms VP Zero Ackermann Tie Rod VP Ti Drag Link VP Stage One Kit AMF Racing Aluminum Panels all around, including diff protector w/ pinion wrap. Possible: VP VVD Axle Shafts VP Q-Series Lights The links I'm sure are idiot-proof, but with the Zero Ackermann parts and the knuckles, will there be any rubbing on the stock tires and wheels? I heard there would be and would need either VP Wheels or wider hexes. Will I need any other parts than i listed to install and properly use those parts? With the possibles list, would I need anything extra with the VVDs? And if anyone has them, how do you like the Q-Series? I can't find many pics or vids of them working at night. Many thanks, I appreciate it. |
11-01-2014, 11:20 PM | #2 |
RCC Addict Join Date: Aug 2012 Location: The Garage!!!
| Re: Simple noob questions on a stock Wraith.
You be just fine with that list but I personally like blue monkey links & steering! Nothing wrong with vp but bm has high clearance lowers & better steering linkhttp://www.bluemonkeyrc.com/catalog/product_info.php?cPath=51_92&products_id=235. You can also save a few $$$ with Axial universals that are very strong. Instead of stage 1 vp ya may want to get scale chubs & knuckles(especially chubs they clamp on axle which dont work loose like others) |
11-01-2014, 11:28 PM | #3 | |
| Re: Simple noob questions on a stock Wraith. Quote:
The Zero Ackermann arms and tie rod are supposed to give extra clearance over the standard tierod. It seems to require their knuckles, which is cheaper to get as the Stage One kit. I was also going with the VVDs as they are rebuildable and have seen people posting about axials failing early. | |
11-01-2014, 11:40 PM | #4 |
Np! Stage 1 is cheaper but you will need beeftubes with just two lil screws holding chubs on! The plastic housing will strip out. So it is easier & better to get scale chubs & you can still run ackerman setup...the Axial unis work great & take much abuse trust me just set end points on steering correctly! Go with bm for links they have steering for ackerman also & more clearance. BESIDES you will use that coupon soon enough on other mods.
11-02-2014, 12:45 AM | #5 |
Quarry Creeper Join Date: Jun 2014 Location: San Mateo
I double ++ the Blue Monkey links and tie rod, just look at the bends and you will see the bends are better and the tie rod doesn't rub your diff cover.
11-02-2014, 01:04 PM | #6 | ||
Anyone have any experience with the Q Series lights from VP? | ||
11-03-2014, 08:41 PM | #7 |
Newbie Join Date: Dec 2013 Location: Highlands Ranch, CO
The links I'm sure are idiot-proof, but with the Zero Ackermann parts and the knuckles, will there be any rubbing on the stock tires and wheels? I heard there would be and would need either VP Wheels or wider hexes. I did the VP stage one and the drag link rubbed on the stock wheels. I took the wheel chucked it up in my drill and with the drum sander bit in my Drexel I made a 45 degree chamfer on the inside of the wheel to clear the drag link. I later upgraded to Gearhead cac wheels which clear just fine. |
11-03-2014, 10:47 PM | #8 | |
11-04-2014, 11:40 AM | #9 |
Newbie Join Date: Dec 2011 Location: Alexander
Sounds like you have a great list going on. I tossed the stock wheels long ago and run Mayhem Engineering. My opinion is there the best double beadlocks on the market hands down. I have three sets of 2.2 and one set of 1.9. You will shred a tire before losing a bead. I run vp titanium links and steering on all my rigs because I have not had a single issue one. For the vvds I just broke a set, but we're abused as well from multiple g6 events and huge power on 3s. If your going to be running brushed motors then they will hold up fine. As for the axial HD universals they will live as well. I've only broke one set of those twisted the long shaft in three pieces.
11-04-2014, 01:33 PM | #10 | |
Simple noob questions on a stock Wraith. - Similar Threads | ||||
Axial Wraith stock ESC questions | Robchinchilla | Axial Wraith | 2 | 01-11-2013 05:00 AM |
Noob to R/C with Wraith and Questions | SoCal_80 | Axial Wraith | 16 | 04-08-2012 07:27 PM |
A few simple LCC questions | HurricaneSpike | Team Losi Comp Crawler | 6 | 11-29-2011 09:08 PM |
2 simple questions...that i am sure have been answered before :( | avoidsthelight | 1.9 Scale Rigs | 6 | 09-09-2010 11:59 AM |
