Troubleshoot Servo Stock servo and electronics. If I shorten the steering range it doesn't do this but making the steering open up more it sounds like a stripped servo. I changed out the plastic bushing for the fast eddy bearing thinking it was the slop but it did not help. Here is a short video of what's happening. Any and all help would be appreciated. Axial Wraith Servo - YouTube |
Re: Troubleshoot Servo Has the servo been run through water or mud |
Re: Troubleshoot Servo Yes it's my 8 yr old son and he most likely has once or twice. |
Re: Troubleshoot Servo Its done! I would shop for another Servo many options...If ya want to go cheap Solar772 its almost double torque without bec but 417 at 7.4v with bec $23 or buy stock for $15-$20 either way Solar is best bang for your buck!"thumbsup" |
Re: Troubleshoot Servo in a pinch you can flip the servo gear around. find the broken one and flip it 180 degrees. Servo's arent 360 rotation so you only use half the teeth. It'll get you through until you break again, or buy new. +1 To solar d772 @ 8v |
Re: Troubleshoot Servo Ok thanks guys. I'll just replace it. Sounds much easier. I would have never thought swapping parts on these would be much like swapping parts on my Jeep |
