11-15-2014, 11:57 AM | #21 |
| Re: RC4WD Wraith Portal kit! |
11-15-2014, 12:15 PM | #22 |
It seems good in theory. But if I want portals, I want them done right, with at least 1.5:1 reduction, and the gear reduction AFTER the axle steering joint. Did I miss any mention of the maximum steering angle? |
11-15-2014, 01:00 PM | #23 |
RCC Addict Join Date: Oct 2012 Location: Charleston South Carolina
Some people can't be pleased, can they? If you want something that special, then YOU buy the tooling, machines and design software and go make it. |
11-15-2014, 01:01 PM | #24 |
Quarry Creeper Join Date: Jan 2012 Location: Durango
Wish they made this for their centered rear axle housing. Ill have to wait and see if they release that for my build
11-15-2014, 01:06 PM | #25 |
These wont fit the d44's will they?
11-15-2014, 01:32 PM | #26 | |
| Re: RC4WD Wraith Portal kit! Quote:
Both the male and female bits are splined, they may work. Best to ask the source though. | |
11-15-2014, 01:37 PM | #27 |
11-15-2014, 01:48 PM | #28 |
I thought the d44s had their proprietary chubs?
11-15-2014, 02:02 PM | #29 |
I do like that the portal is mounted to the axle. Although there would be some strength advantage having the UV joint before the reduction, since there are 1:1 ratio they made the right choice to reduce scrub radius. Pretty cool bit of kit. |
11-15-2014, 02:11 PM | #30 |
| Re: RC4WD Wraith Portal kit! I don't recall them being different. I had the D44 knuckles and chubs on a Wraith axle that turned into those custom axles. The D44 tube doesn't have a continual spline on the male side, rather, just the few to help with the castor adjustment. Last edited by Lentsnh2012; 11-15-2014 at 02:13 PM. |
11-15-2014, 02:13 PM | #31 |
awesome. Something I would like to do but we are talking about big $$ there. lol
11-15-2014, 02:48 PM | #32 |
RCC Addict Join Date: Jul 2008 Location: San Diego
I think the portal would put too much stress in plastic axle housing. You might want to step up to aluminum diff housings.
11-15-2014, 02:58 PM | #33 |
[QUOTE=Lentsnh2012;4944369]Give them time, if there is that much demand, I'm sure they'll make a kit. It's only two same length axle shafts. That would be awesome if they do! Now more money into my build! |
11-15-2014, 04:06 PM | #34 | |
I'm sure that these RC4WD weren't designed for a lot of drivetrain stress (the gears appear to be small); it would just be another thing to break if you tried. Brushed motor crawler or scaler would be best. | |
11-17-2014, 08:07 AM | #35 |
Rock Stacker Join Date: Mar 2013 Location: Irwin
These would be sweet upside and with street tires for a wraith drag racer.
RC4WD Wraith Portal kit! - Similar Threads | ||||
Rc4wd Portal Axles | Jersdunz | Tamiya TLT Crawlers | 7 | 05-05-2007 09:19 PM |
